sajunky
To save searching, there are details.That's news to me.
So ideally the Ares 2 should be plugged into a USB 2.0 hub using a usb2.0 cable instead of directly into the PC?
I would need to purchase a usb 2.0 hub to test this out.....
Yes, it is a common issue, not only related to Ares. A DAC use high speed USB 2.0 transfers. Super speed transfers use a separate pair of wires which is unused and floating (unterminated) on the receiver side. It cause interference and under certain condition can disturb transfers.
Cable issue was Lolito's own discovery, for me it was to obvious. I just recommended to use USB 2.0 root port on the PC (if present), and/or USB 2.0 hub. 2.0 port is less noisy, 2.0 hub do not generate 3.0 frequency noise as well. BTW, it does reclocking (but not reclocking in audio means - it is buffering each frame and preparing a new frame for sending, based on its own clock, called Transaction Translator). Only important on longer cable runs.
If a hub is attached to the external power supply, it perform additional function, ground loops redirection (the same as iDefender).
An additional comment on using 2.0 hub. From the ground loops redirection perspective the best is to use a DAC as the only one device on the hub. If other devices are attached, it has to be a hub with MTT (Multi Transaction Translator) feature. It prevents slower devices (like keyboard or mouse) from degrading uplink to a full speed or even to low speed. It also prevents from enumeration errors. If you remember how USB 1.1 required to load drivers separately when plugging to a different port, you know what I mean.
