john57
- Feb 16, 2009
The topping driver should not be affecting the Denafrips as it does not affect mine. Did you reboot the computer?
Yep, I immediately rebooted upon prompted by the denafrips installation I believeThe topping driver should not be affecting the Denafrips as it does not affect mine. Did you reboot the computer?
no mac issues with your ares? what version is the firmware? if you plug it and then unplug it, any problem?Spent the entire afternoon and most of the evening so far stuck to my Stax rig. I took the plunge on the Ares II because I have been happily using my Luxury & Precision P6 Pro and LP6 DAPs as USB DAC and LO into my desktop rig, with much joy. I grew up around tubes and before R2R DACs became obsolete in mainstream music gear. Anyway, this sound signature takes me further down memory lane and nostalgia. With USB DAC from my M1 Mac Mini and desktop power from Isotek EVO3 Aquarius, there is something to be said for a desktop R2R DAC. Happy. Very happy.
Where do you rank Ares II compared to your other sources?Switched from the Stax rig. Listening on Apple Music on the M1 Mac Mini, controlled by the iTunes Remote. M1 Mac Mini > Denafrips Ares II > Cavalli Liquid Gold > Abyss 1266. Relaxed listening before another manic week ahead…
Hmm… I think it is a great source. Brings the desktop R2R presentation to the table. I can say that it stands its ground against my other dedicated DAC, the Bricasti M1 in terms of enjoyment. Though of course, the latter is almost 10 years old now and I am sure there has been so much progress in this space. The reason I had picked the Bricasti all those years ago to replace my Benchmark DAC was because I wanted something more natural and relaxed.Where do you rank Ares II compared to your other sources?
HQPlayer can use it and even supports DSD2048.Recently got my Ares ii and I'm really enjoying it.
Just curious if anyone is using the DSD1024 capabilities of the dac. If so, which software are you using?
I'm using Jriver, but it is limited to DSD512 (8x).
Here is a simple fix & yes this also works for AMD update driver conflict issues as well: https://github.com/lostindark/DriverStoreExplorer/releases very simple install, run Rapr scroll down to Sound, Video & Game Controllers then manually check for older versions, click & delete driver.Yes, driver versions can use conflicting DLL's. Install an older version first, then update the other device which comes with the newer XMOS version. It may not work, but usually upward compatibility is preserved.
If both devices are needed in the same time, uninstall both drivers and use built-in UAC2.0 driver.
