tangent
Top Mall-Fi poster. The T in META42.
Formerly with Tangentsoft Parts Store
- Sep 27, 2001
They don't. But they do mark where, on the bottom side, the copper is.
That particular confusion has come up more than twice. I may have to do something about it. I guess you're asking in advance of actually seeing the Radio Shack board?
Yes, it's about time to weed the parts table again...about as much fun, too.
Trivial. See the panel components article, linked from the CMoy tutorial.
The only easy way is to wire them in parallel, which only works if you're using them separately. If you plug two sources in, what happens depends on the sources. It might actually work okay, or it might sound rotten.
Originally Posted by infinitesymphony /img/forum/go_quote.gif Oh, wow... I didn't realize that those painted areas transferred electricity! *facepalms* |
Some parts have been replaced or superceded by newer versions |
how difficult would it be to have two RCA L/R input? |
Also, would it be possible to add RCA inputs in addition to the 1/8" input? |
