b0dhi
- Oct 12, 2005
Sorry, pseudoscience? How exactly is comparing a measurement to observation pseudoscience? That's called empirical evidence and it's the basis of real science. I know the matching technique isn't specific, nor is the distortion type specified for the Sennheisers.
If you read the next paragraph you'd see my point was outlined exactly so that I wouldn't have to clarify as I'm doing right now:
That's one of the reasons why I'm really looking forward to comparing the TakeT H2 with the GS1000. As far as I know, the H2 doesn't generate a significant reactive current, and if there's a big difference in bass definition between the two, dampening factor will likely be the cause. At low frequencies the differences in speed between the two drivers aren't as important, whereas dampening is most obvious at those frequencies. Should be interesting
Originally Posted by hiisinux /img/forum/go_quote.gif hello pseudoscience first of all how thos grado drivers are matched isnt mentitioned they could be matched for that 0.05db at 100khz or 5hz not mentitioned... so it has no worth... and anyways ild (interaural level differences) is one of contributing factor for spatial sound in headphones... |
My point is, just because a number seems low on a spec sheet, it doesn't mean we can't hear it, and it doesn't tell you the whole story on how it will relate back to hearing. |
Originally Posted by slwiser /img/forum/go_quote.gif Oh Well back on the farm... and Getting back to my personal favorite subject damping..... I was rereading a web page by David Berning where he shows that his amp's design make the load appear to be 4000 ohms to the amp and the amp at the same time to appear to have an impedance of 0.6 ohms. This results in an extremely high damping factor. |
![biggrin.gif](http://www.head-fi.org/forums/images/smilies/http://hfimage.head-fi.org/smilies/biggrin.gif)
