TheVinylRipper
- Jul 12, 2007
You have a pair of different components hidden behind an acoustically transparent barrier and arranged in such a way that it is possible to instantly switch from one to the other component. You will also have taken pains to ensure that the volume levels between the different components are as similar as possible within the limits of your instrumentation.
The test subject and the person administering the test have no idea which setting of the switch is related to which component under test.
The subject is asked if they can tell any difference in the sound quality from one switch setting to the other and if they can, then which setting is of superior quality.
Again, neither the subject nor the test giver are aware in any way of which switch setting is choosing which component.
You run the test multiple times for each subject with multiple subjects while recording the answers to the question at hand.
You also run a series of tests in which the switch setting do nothing, there are no changes at all and record the answers to those tests, again without the knowledge on the part of either subject or tester as to what the settings of the test switch might control.
Only after testing is completely finished is it revealed which components were related to which switch settings and what the answers to the questions by the test subjects are.
That in a nutshell is double blind testing.
It is done all the time in cases far more serious and far more difficult than evaluating audio equipment, specifically testing of drugs.
