Originally Posted by peterpan188
Thanks for all of your inputs!! Great advises there!
tomb: For now I would want to get a drill first, in case I need to do another kind of stuff except panels. Nonetheless, your deal sound very interesting. But When I took a look at harbour freight's website, I couldn't find the drill press at your price. Can you give me a link?
arnesto: Same for costco, I couldn't find it in their website!
It wouldn't be a life time purchase, but I do want them to last me quite a while and be functional and useful in different ways. Looks like Dewalt got alot of good reviews here. Which models are good? I found some from Home Depot:
12V, DW927K2
Corded, no clutch
I guess I shouldn't limit myself on cordless. If corded ones are lighter and better, please give me some suggestions.
Thanks again,
Peter
It's not as though you could buy one drill and have it work (as) well for everything. You have to look at it as investment tools vs immediate need tools... what you can afford at any given time or justify per the use.
No matter what cordless drill you buy, in 10 years the batteries will be shot. In 10 years a decent corded drill or drill press will be in the first quarter of it's life unless you're using it constantly, professionally.
For the dollar, you'll get a better build from a corded drill but for your described uses, any merely average grade cordless would suffice. Corded drills are poor used as a screwdriver but you don't need a > 12V cordless for that either. Years ago I did HVAC work screwing hundreds of screws a day and found a Makita 9.6V the best option, more voltage just meant heavier to use continually, no gain.
Given your questions, it would seem you are just starting a tool collection. I think it would be better to get an assortment of medium quality basic tools instead of splurging on high-end stuff unless you have a sudden increase in income that makes it seem likely you'll buy a lot more tools in the immediate future. It can also be handy to have more than one drill set up to use simultaneously when a project has two or more hole sizes.
I'm not impressed by my last Dewalt 14.4V, the batteries degrade too quick. I'll get a Bosch or Makita next time but I'm think about just rebuilding the Dewalt packs instead as the drill itself is fine besides the batteries. If I were in your position I'd get a $60 cordless drill, a $40 corded drill, then use them for awhile to find out what features you find lacking if any. They'll last you at least a few years and having the corded drill you are covered for tasks where the cordless can't cut it (lower torque capability/build).
As for buying Harbor Freight drill presses, IMO they're a lottery, you need to set it up right after purchase because some have more runout than others, you may end up wanting to take it back and exchange a time or two or three. Unlike some tools where there might be one manufacturing mistake, one HF press I bought had every part a little off-spec and there was no reasonable correction except to return it. I drill PCBs with carbide bits though, it starts getting expensive if the runout breaks bits.
For casework a HF press is acceptible but if you have higher precision jobs to do too, I'd step up to at least a Delta 10" (about $100). Don't forget about the cost of bits when budgeting, drills aren't so useful without a wide assortment.
