hgpsemaj
- Feb 12, 2015
SONORE audiobyte USB US$693.72 each
http://www.yoycart.com/Product/522226460134/
I think you 'forgot' to mention the currently available Singxer F-1 solution. The best USB DDC I have heard by miles ...
You can follow the thread I've started here:![]()
Did not see your PS initially.
A standalone application closer to a conventional PC is Rune Audio which pulls in the audio files without the need for another PC other than the file server itself.
http://www.head-fi.org/t/795895/a-70-bit-perfect-audio-player
I use LMS with the RPi and it is a little different but that is a software choice rather than a RPi specific, that probably made the RPi sound more complicated than it was.
I2S makes sense only if one is able to connect the RPi directly to the DAC on the DAC motherboard, going thru I2S converters nullifies some of the benefits.
The RPi2 and above will play 384kHz tracks without dropouts, RPi2 is a 900MHz 4core ARM with 1Gb of memory
RPi3 is 1.2GHz
Some numbers on my RPi2 Picoreplayer on the RPi:
DSD128 as DoP (equivalent to 384kHz PCM): Approx 20% of 1CPU core, 0.20/4 = 5% busy overall (load average: 0.20)
Track is one of the Native DSD tracks justlisten_JL001_JL001+stereo_05_Mahler1_finale_session_BFO_DSD128_2ch128.dff
PCM 352kHz : load average: Approx 11% of 1CPU core, 0.11/4 = 2.75% busy overall (load average: 0.11)
Track is from 2L Krambupolka 2L-068 stereo-DXD 01 15
Hi ! sorry to jump in. It looks very well built indeed. Are you aware of a web site of the brand ?
How do you power it ? i mean ... directly from the pc using the usb bus power or do you use a special usb power supply ?
Link is missing![]()
Thanks a lot !
regards, gino
Sorry here is the thread link (using my darn tablet last night - it's very hard to cut and paste to a Headfi post):
http://www.head-fi.org/t/803111/xmos-xu208-usb-bridges-the-latest-gen-has-arrived
The Singxer F-1 is USB powered (see my thread for details on my set-up), just to say using a W4S Recovery with LPS external power, and a bunch of other enhancements.
It is by far the best sound I have ever heard in a music system I've owned - rivaling my old $30K analog set-up. Some things it's way better on, and a few that great analog is slightly better at. But overall I'd say just killer good. The F-1 (now fully burnt in) is light years ahead of all other DDC's I've owned (including the PUC2 Lite, Hydra Z, modded Breeze Du-U8, DXIO Pro3a, Gustard U12, etc...).
The Singxer X-1 is very, very good as well. The SU-1 will be launched in May:
Here is the Taobao website:
https://world.taobao.com/item/528898172401.htm?spm=a312a.7700714.0.0.kq275g#detail
Here's the short resume on the so called 'new gen' ddcs.
All are based on a (somewhat) newer and more powerful xmos chip... all sold (apparently) by these guys http://singxer.com/pr.jsp ... all using the somewhat shady kind of drivers that you have to dload from some chinese site.
the F1 you linked is the bare board. You have to add a case and power (usb or other) ... and if you want any output other than the std coax spdif, you need to diy it. About $180+diy costs.
the SU1 linked above is the fullbox device. Presumably with the same (or similar) f1 board inside the nice case ... and all the usual extras: trafo power, aes/bnc/i2s outputs, clock output, etc.. About $300
there are a few lesser devices (X1 & Q1 iirc) which are cheaper & simpler bare boards ... ~$100 or less. May be a good start but they don't look as good as f1 ... e.g. little or no isolation between the 'dirty' usb input side (the xmos side) and the 'clean' output side (the side with clocks) ... no extra fpga on the 'clean' side .. cheaper clocks ... etc...
Which one is best for you?
Unfortunately (and in spite of the amazing amount of SPAMalot/FUDalot/HYPEalot posts), nobody can really say that. The difference made by any DDC depends on 3 main factors: the quality of your power, of your digital source and of your Dac. And the SQ diffs with a ddc could be anywhere between non-audible and my-wife-heard-it-too.
In my setup (filtered power + laptop + minimaxplus) the old-gen ddcs were between non-audible & barely-audible ... only the puc2 is slightly above that range.
Hi and thanks again ! no more question. I understand it is really something special.
also IMHO a good analog rig is the reference. With good analog it is easier to get music and not only sounds.
And also the price is very right.
I will stop asking and start reading ... sorry again.
Kind regards, gino
I'm considering the F1 board as I only need S/pdif output. Do you know of any case that will adapt to this board? What about clean external power?
Thanks for your help, I'm new to DDC.
