AC1
- Sep 14, 2001
Hi DA,
Aurios are a pain in the neck sometimes especially with something like a VD power cord which can also negate the effectiveness of the Aurios.
Right now I am using double isolation device for my equipment. I use bearing isolation devices, Aurios w/tcb, Darumas, Stillpoints to float a MDF board, where I put the K Works Isolation base (which I liked better than the bearing isolation devices on its own) for the equipment to sit on. It has been an extremely effective combination (if not a bit costly).
Originally posted by DarkAngel For my reference system I still use Aurios 1.2 with top bearing under CDP which gives just a touch more detail retreval, but can be hard to use (or impossible) with some stiff/heavy cables. |
Hi DA,
