onlychild
- Jan 24, 2008
How much of a difference in sound did changing out the caps make?
Originally Posted by onlychild /img/forum/go_quote.gif How much of a difference in sound did changing out the caps make? |
Originally Posted by Spoon Wrangler /img/forum/go_quote.gif To let everyone know, I ended up buying Jgonino's Bada. It was too good a deal to pass up! I can't wait for it to arrive. On another note, I am very amused by the techies duking it out about capacitor heat ratings but I don't think this is the place for it. The DIY forum perhaps? |
Originally Posted by Onkyo /img/forum/go_quote.gif dgm, did you check Mapletree Audio amps? People seem to be happy with them. They seem to be well built, although somewhat too much "home made". The volume knob alone reminds me of Radioshack. But the design looks neat. |
Originally Posted by dgm /img/forum/go_quote.gif OH yes, I had one more question I was going to ask: does a hybrid amp like the Bada PH-12 capture some sound characteristics of a SS and tube amp? Like does it add a little warmth to the sound, but still retain the punchy bass of a SS? Or does it not work that way...? |
Originally Posted by Onkyo /img/forum/go_quote.gif 1. You stated your opinion, I stated mine. I do not see the point of continuing this discussion. |
3. As you might know caps will not only heat up because they are near tubes. Even in SS designs some caps get very hot. Take for example Rotel RSP-1098. This is a fine high-end processor. After an hour of operation it does get hot. And guess what, it's not only the power supply's heat, it's the capacitors'. The above disqualifies your comment on the heat. |
Originally Posted by dgm /img/forum/go_quote.gif Haven't heard of Mapletree Audio, I'll have to check them out. Thanks for the suggestion. OH yes, I had one more question I was going to ask: does a hybrid amp like the Bada PH-12 capture some sound characteristics of a SS and tube amp? Like does it add a little warmth to the sound, but still retain the punchy bass of a SS? Or does it not work that way...? |
