Gyahh.. I just had to be watching an awful movie instead of keeping up on this thread.
About noisy tubes playing cleanly for a few seconds after power off. This is because once you've flipped the switch, you disconnect the transformer and completely eliminate the 60Hz hum from the entire circuit, but the power supply capacitors still have more than enough power stored to keep the sound going until the tubes cool off. The heaters are powered directly off the transformer, so once the power is off they immediately begin to cool off.
Like echo1, I've also noticed that NOS tubes or ones that have been sitting for a long time will often have a small amount of hum until they've been burned in a couple hours. Even the stock tubes did the same thing when I first got mine. Loud humming is the result of a bad tube, or just a tube that doesn't play nice with the circuit. The Electro-Harmonix 6SN7 is a good example of this; I've tried two different ones and let both burn in a few dozen hours with no reduction in hum at all. The Tung-Sol RP I'm using now originally had a moderate amount of hum that only went down a small amount after some burn-in, but has disappeared completely now after all the mods. I wish I still had one of the EH tubes in my possession to see if any of these mods would have an effect on it as well.
I already have a schematic sketched out on paper with all the component values (except for the pre-out caps on the newer Darkvoices), I just need to draw it up on the computer. I think the other schematic is another amp the Darkvoice is originally based on, since the general topology is mostly the same, and the differences lie mainly in the component values.
I'm starting to think I may have to make a parts order sometime just to continue playing around with changes to the Darkvoice, even though I've got mine working just fine. I've got a few ideas kicking around for whenever I want to play with the insides of mine... Add preamp outputs like on the newer Darkvoices, change/upgrade the various components (volume control, output caps, etc), replace some wiring with stranded wire so it can be moved around more easily for modding, add additional tone controls besides my first mod, and probably a lot more ideas as I keep looking at the internals. I think in only a matter of weeks there will be more replacement parts than original parts.
Unlike some source/amp mods, this is more out of sheer fun and curiosity than seeking SQ improvements.
