slash
- Feb 3, 2008
Tell me about your experience connecting a DAC directly into an amplifier.
I plan to use my MacMini 800Gb CD ripped library with iTunes ALAC to feed the DAC with a direct connection into a Pass Labs XA.8 amplifier. The .8 has both single ended RCA and Balanced connections. This system will be stand alone and minimalist with no other source. In the future, if I like what I hear, the plan is to connect a blu-ray player, for movie nights, and eliminate a Yamaha YSP4000 Soundbar, currently used for all music play.
I do not stream music today and rely upon my library and CKUA.com for 100% of my listening through HDMI connector.
Let me know what you use, or, recommend for a Streaming DAC solution or at the minimum a DAC. Also, which connectors to consider. Neutral to slightly warm is what my ear likes so almost for certain I plan to use copper throughout.
Also, if I were to replace iTunes what software should I consider loading into the MacMini and what effort is required to convert my ripped library to your recommendation.
Thanks in advance for your thoughts... I am open to all ideas.
