kennyb123
I use an inexpensive Sony blu-ray player to rip mine. I wish it was easier but I really can’t complain.Really? I thought it would rip SACDs. Well there you go cheers
I just want to probe on this a bit. I am in the middle of trying to get Roon & HQP (CX) > NAA (EX) > Innuos Phoenix > P2 > HDMI > PS Audio DirectStream working.i thought I was also perhaps happy with Roon + HQP on the k50. This was using HQP + NAA but with no up sampling, in other words just using the player function of HQP + NAA. But then i swopped to HQPD for file selection instead of Roon 1.8 and realised I was fooling myself into thinking Roon was listenable to. Even worse was using Roon on the k50 server and Roon on the k50 player.
And, sorry, separate question i guess:I am in the middle of trying to get Roon & HQP (CX) > NAA (EX) > Innuos Phoenix > P2 > HDMI > PS Audio DirectStream working.
And, apologies for all the questions at once: given that I'm not looking for upsampling from HQP, which Antipodes player / renderer provides the best sound quality (and secondarily the easiest setup / reasonably good UX)?And, sorry, separate question i guess:
Since my DAC does its own complicated oversampling, I am actually just looking to get bit-perfect playback of PCM and DSD (that sounds better than Roon) out of HQPlayer...
Hi there, I did quite a bit of messing around since I got the K30, and following Triode's and Clive's posts in this thread.I just want to probe on this a bit. I am in the middle of trying to get Roon & HQP (CX) > NAA (EX) > Innuos Phoenix > P2 > HDMI > PS Audio DirectStream working.
In your opinion, Roon (CX) to Roon Ready (EX) is the worst I'm assuming.
>> Have you tried Roon (CX) to Squeezelight? This is what I'm using now, and it's noticeably / substantially better than Roon Ready.
Next level up in SQ, if I guess correctly, is Roon & HQP (CX) > NAA (EX)?
And you are saying that (for local file playback anyway) turning off Roon Server and using the (very basic) HQP UI to load and play files is noticeably / substantially better than Roon/HQP > NAA?
Sigh. Please confirm, and I will experiment with that. : )
Has anyone else confirmed the same? It's not that I don't believe it, I'm just tired of messing around. : D
And of course the Roon UI is much more pleasant.
I would skip HQPlayer because your DAC does its own scaling. Roon/Squeeze is about the best Roon will sound. I believe there is a video on Antipodes' website describing how to set it up.Since my DAC does its own complicated oversampling, I am actually just looking to get bit-perfect playback of PCM and DSD (that sounds better than Roon) out of HQPlayer, at least initially. Anyone know what settings I should be using?
I have playback of redbook right now, but I can't get anything highres to play. : /
Strange....Hi there, I did quite a bit of messing around since I got the K30, and following Triode's and Clive's posts in this thread.
What I found is similar to Triode User, where Roon Server / Player seem to be the darkest / warm / muddy sounding combo. Roon / Squeeze is much better with overall music getting quite a bit brighter. Although from previous post by Triode, it seems Roon is creating lots of traffic and performance use in the background.
I can confirm this, where using CPU load diagnostic tool in the my antipodes page, the CPU load for all 4 cores jump up to 7 - 12 %, sometimes 20% when I just use an iPad to browse Roon, and going through different pages, albums etc. So this confirms that Roon is using quite a bit of performance and probably sending quite a bit of network data so you can speedily browse it's very nice interface that you pay for.
And from what I can tell, SQ wise, it's best to keep CPU and Network traffic as low as possible.
So if I ever want to get as much SQ out as possible, I would switch to using MPD as player, and downloading an iPad app called "mconnectHD" to browse the music. It seems to work easier than getting HQPcontrol to work. The music just pops up automatically in mconnect vs HQPcontrol where you have to go HQP interface to do a manual refresh. I have to anyway in my basic understanding of how the app works. Using this combo, the server computer CPU load stays around 0 - 2% sometimes 3%.
Anyway, my 2 cents. Hope this helps.
Thank you both. I've spent $8.49 on mconnect for iPhone and another $8.49 lol for the iPad version (I wish my other tweaks cost this much) and have TIDAL and Qobuz playing through the EX MPD player.I would skip HQPlayer because your DAC does its own scaling. Roon/Squeeze is about the best Roon will sound. I believe there is a video on Antipodes' website describing how to set it up.
I agree though with @atya35mm above that MPD is the best sound quality. You lose the feature richness of Roon but gain much better sound quality.
I really hope that. Like Innuos did with their new 2.0 software. Most users I have seen says SQ improved there.Will AMS3.1 by itself (no EX/CX upgrade) bring a sonic improvement over sonicorbiter 2.7/2.8 or just a different gui?
It does seem excessive although that’s just my experience from one listening session. Where I quickly flip between myantipodes cpu usage and roon to see how browsing roon impacts performance. The jump to 7-12 % only lasted few seconds after browsing Roon, and settles back to 2-4% if I didn’t flip back to Roon on the iPad. I could probably do more testing on this to see if it’s a glitch like you said, but currently loving it too much just using MPD playing local SSD files.Strange....
OK, I have the K50 but only have 0-1 % on the sever with Roon and 0-1% on the player with squeezelite.
My CPUs are almost idle. There is now way this should be ongoing 7-12%
The odd occasion the usage is similar on the server with Roon but it is a glitch and I have to power off and on then the problem is sorted.
The issue is with Roon stop it under the software and restart sometimes it also resolves the issue.
For the avoidance of doubt my K50 is at room temperature.
Had the same issue a few times.
Has anyone else had the same issue ?
This is a fascinating topic. To the extent that we are implying that CPU usage is inversely related to SQ (which seems reasonable to this non-techie), should we be outsourcing heavy lifting (HQP upsampling certainly, and even Roon serving) to a different box which is disconnected from the (in my mind) more impactful renderer (i.e. the last thing that touches the DAC)? I'm curious in a sense how Antipodes would characterize their current top-line products when running HQP upsampling vs running barebones MPD / DLNA server (MinimServer i guess?).It does seem excessive although that’s just my experience from one listening session. Where I quickly flip between myantipodes cpu usage and roon to see how browsing roon impacts performance. The jump to 7-12 % only lasted few seconds after browsing Roon, and settles back to 2-4% if I didn’t flip back to Roon on the iPad. I could probably do more testing on this to see if it’s a glitch like you said, but currently loving it too much just using MPD playing local SSD files.
I’m really liking the quality of SSD vs. streaming of the net at the moment. It could be because I haven’t spend any $ optimising my network connection. The K30 just gets connected via the black stock ethernet cable it comes with to my wireless network point. Have you guys got good experience with buying good quality after market cables? With the costs of some of these cables like the AQ Vodka / Shunyata range, I’m debating whether I should just use the fund to buy more high res albums to add to the SSD collection. Qobuz having some nice discounts at the moment.
I just figured this out.. it is NOT straighforward lol (at least not compared to Roon).I was looking in the CX Roon Server Diagnostic Event Log line items for the % processor usage and didn't see it. Any clarification to help me find it would be appreciated.
Also, on Antipodes' website, with the MPD support video "under construction", what is the recommended server option and how do you transfer files from the music library to a "playlist"? Is the "Playlist" location part of the MPD renderer app?
Sorry for the basic questions...
I did the 2.7 to 2.8 upgrade a year ago. I did not notice a sonic upgrade. The software player upgrades were definitely worth it. I have had many hqplayer updates and some mpd. MPD does not require a server and using a controller app will provide direct play which is the best sonics imho.I just tried Roon Server[CX]/Squeeze[EX] for the first time last night. I heard a more open midrange and treble but it didn't seem to improve on transient and midrange blur that I am also used to with what I hear as a more closed in sound from Roon/RoonReady. Mark J mentioned the new power supply will significantly improve on transient delivery.
I don't mean to stir the pot here but last fall there was some talk from the US support center that a new LINUX version was out that would improve SQ but the upgrade needed to be performed at the service center. At the end of last year the story for the delay was that it needed to be regression tested/certified with the "new" Antipodes OS SW. No clarification was provided as to whether that was integration with 2.8 or the unannounced [at least to me at that time] AMS v3.1.
The topic of the new LINUX update seemed to fade away and I recently inquired about it with Mark Cole. His response was that the SQ improvements were to come from the PS upgrade and my inquiry pertaining to a factory performed LINUX upgrade was not responded to. Since [per Mark C] the AMS v3.1 will be pushed out to existing CX/EX users who don't send their units in, I presume there is no new LINUX update. Perhaps this was only a smoldering rumor that I picked up from last year.
