td19
The two SSDs can not be viewed as individual drives in File Explorer or Finder. They are configured as a single logical drive.
August is not very far away, a couple of months or so.I believe the Update will be available August along with upgrade to OLADRA technology for CX and EX.
I switch between the USB and BNC out on the K50 to the Dave and DaveMsacler if that counts (similar).Been trying out the SRC-DX dual mode to chord dac dual BNC inputs from Antipodes EX audio powered USB output and then using the Antipodes EX second non powered USB output going direct to chord dac USB input using a Acoustic Revive USB-1.0SPS which has separate power/audio.
Was trying to do a direct comparison by switching the input on the chord dac from dual bnc mode then to usb so I can compare 24bit PGGB through SRC-DX and direct through USB.
Switching the input on the chord dac from dual bnc to USB made no change; it will remain on whichever input is first recognized and will only switch if you disconnect the other USB cable.
Anyone else tried this?
Welcome… my experience is that Antipodes does benefit from burn in. I’ve been using my EX as a roon server and minimserver with playback from network 2 to a usbridge signature, src-dx and tt2 (dbnc). Although it may not be as powerful as a roon server, there is a sound improvement over a regular computer.Hi, new to posting but have read through this thread and thought I’d join in having just acquired a S40.
Two things worth mentioning, first, it has made a significant difference compared to the Project Stream Ultra I was using previously. So much so it has necessitated a period of adjustment regarding speaker position and room treatment. Second, I was interested to see mention of burn in as it does seem to vary a bit, especially with the high end. It has sounded glorious, but, it has also sounded worryingly harsh.
During the glorious moments, the change in sound fits all the cliches we know and love so I won’t repeat them. However worth noting that if I’d got the same improvement in sound having just changed to a more powerful amplifier, I’d be less surprised than I am having gained so much from the source alone.
I’ve settled for the moment on treatment and speaker placements and now need to let the S40 settle/burn-in as I’ve only had it a few days.
As an initial assessment I’d say huge potential but not yet showing all I hope (and expect) it to be capable of.
FYI
using Qobuz, Mscaler/TT2, Norma IPA 70 and Marten Duke 2 speakers.
I’d definitely buy a product if it was called ’Feet Thingies’, they’d have to be good, class…The only thing I haven’t gone down the rabbit hole with are feet thingies, and haven’t blown a load on power conditioners, ( although plenty have and seem to like it) but tried power cords that look like it would power up a aircraft carrier…..its athletics, it’s insurance, it all may help or seem like it might. But that’s just my humble and somewhat limited opinion. I haven’t done any srx boxes or bnc stuff given my dac. But I’m I cable believer….I have no stock of anything.
Are you guys still experiencing this as I am currently using the SRC-DX playing PGGB files and not having any high pitch squeal when paused or stopped. I do if I go direct USB from EX to dac.Have you noticed the high pitch squeal when pausing or stopping a track on your EX? If allowed to finish there is no squeal. I find if after a pause or stop I quickly play a non pggb track and then stop the squeal is gone.
It seems to be another reason to use the SRC-DX. It stops the high pitched squeal when MPD is stopped or paused on the Antipodes when playing high res files (705 / 768).Are you guys still experiencing this as I am currently using the SRC-DX playing PGGB files and not having any high pitch squeal when paused or stopped. I do if I go direct USB from EX to dac.
