Originally Posted by falcogreg
Thanks for that great explanation! BTW, I also went with the 6sn7 tube option. Guess I forgot to mention that in my initial post. So, based on your expalantion, it appears it is something I may want to consider, no? If I understand correctly, the money I save in tubes by buying 12sn7 tubes instead of 6sn7 tubes will eventually pay for the upgrade? What are good recommendations for these tubes (6sn7 or 12sn7) and a good place to buy from? Are there sonic advantages to the 12sn7? I only ask because you would think the higher voltage would have an effect on electron flow to the plate and hence, affect the sound?
I would take this off line but I think it is a good discussion that others may be interested in.
Thanks,
Greg
The 12sn7 option in the SLAM forces you to use 12 volt tubes only. You wont be able to switch back in forth because of the way the 5687's are wired. There is only one octal tube..... so the savings would have to be applied over a much longer time period. Depending on which 6sn7/ 12sn7 tubes you wanted to use and how long you keep the amp.... I dont see the 12 volt option as a big advantage with the SLAM...... unless you want to use the extremely expensive tubes and plan to keep the amp for years.
That said, I went for the 12 volt option in my SLAM because I have so many 12sn7gt tubes. I found the upgrade is much more difficult to implement with the SLAM despite the upgrade only addressing the one octal tube.... and it costs more.
The lay out had to moved around and the complexity has increased two fold. I would stick with the 6 volt version if I were you.
But, there is another less expensive alternative.
I use octal to loctal tube socket adapters that allow you to use another tube called the 7n7. This tube is electrically identical to the 6sn7.... the only difference being the loctal tube base. You put the adapter in the amp and the 7n7 in the adapter.... done. The trouble is finding someone to make you some. The guy who builds them for me works and goes to school full time. He cant crank out more than 3-5 a week and he is way backed up. Now since you only need one he may do this for you. I will give you a pm with the info. I am not connected with him in any way except I talked him into building these for me. The idea worked out better than I ever imagined..... and people who pm me with questions can tell you.... I suggest this often as a way around high tube prices.
The loctal 7n7 cost around $7-8 each. I recommend the short bottle gta plate type. There is a tall bottle gt type but they dont hold up. I may have got a bad batch of the tall bottle 7n7's but the short bottles are indestructable. This short bottle tube is better than any new production 6sn7 and I prefer this tube to all but the very best 6sn7's.
There is a 12 volt version of this 7n7 tube called the 14n7. This is actually my favorite tube. The 14n7's are all made with an extra support rod and I have had none of the reliability issues I had with the tall bottle 7n7's. The tall bottle 14n7 types are true 6sn7/vt231 equivalents. The short bottle 14n7's have true gt type plate construction. I use the 12 volt option along with the tube socket adapters in this instance.... to use the 14n7 tubes. The 14n7's can be harder to find. But I paid $2.25 -3 each when I did find them.
I put a lot of information out there, so if I confused you somewhere along the line, feel free to ask for a clarification.
