Ticky
- Oct 24, 2003
Agreed. When I had the Supreme, I used the crossfeed function all the time. But when I was auditioning a bunch of amps for my upgrade, I had to do without crossfeed inorder to get a "fair" comparison between amps. After a few weeks without crossfeed, I've come to prefer listening to my headphones in straight stereo. Regardless of whether I'm using the HR-2 or the TBH, I now prefer listening without crossfeed.
Perhaps this might be analogous to the situation of quality speakers. I've noted that lower quality speakers often need "help" from sound processing to make them sound half-way decent. Think "bass boost," "sen-surround," and all that stuff that comes with regular boomboxes or mass-market components. On the other hand, on a high quality pair of speakers, no sonic manipulation is necessary to bring out the tight bass, broad soundstage and crystal clear trebles.
A note on the Meier crossfeed. In the brief time I spent with the Corda HA-2, I've found that the Meier crossfeed doesn't alter the tonal characteristics of music as much as the Headroom. However, I still prefer the Headroom's crossfeed over Meier's. The Headroom might mess up the mid-range a bit, but it is more fun to listen to. The Meier crossfeed is abit clinical. Also the Meier crossfeed is very subtle. Half the time I couldn't even tell if I have it off or on the low/medium setting.
Originally Posted by Hirsch I've found that as amp quality goes up, the need (or desire) for crossfeed goes down. I suspect that those of us that have had good stereo speaker setups, where we're used to combining the sonic input from two transducers into a three-dimensional image, are likely to want crossfeed less. It seems to me to be an artificial way of doing what should be happening naturally in the listening experience. I have yet to hear a crossfeed device that does not have some negative impact as well. On the best of them, the negative effect is negligible, though. |
