Creek power supply
Jun 7, 2008 at 5:06 PM Thread Starter Post #1 of 10
Wid
I have a Creek OBH 11 amp that needs a power supply. Where is a good place to find a descent quality power supply to replace the failed stock unit? I don't want to spend a ton on the unit as it is a back up amp at this time.
Jun 7, 2008 at 5:50 PM Post #3 of 10
Jun 7, 2008 at 6:18 PM Post #5 of 10
Elpac is fine, they make nice supplies.
As long as it is of good quality and supplies what the amp needs, no OEM seal of approval is necessary.
Jun 7, 2008 at 6:20 PM Post #6 of 10
Jun 7, 2008 at 6:51 PM Post #7 of 10
Originally Posted by ciphercomplete /img/forum/go_quote.gif
This worked perfectly with my OBH-11 and was a significant upgrade over the stock wall wart.
Elpac
Thanks for the suggestion, it looks like it will fit the bill. Anymore suggestions are welcomed.
Jun 8, 2008 at 4:13 AM Post #9 of 10
The stock walwart OBH-1 that came with the Creek OBH-11 was furnishing 27+ volts to my headphone amp. I picked up a regulated 24v ELPAC power supply from newark.com. Works great and it was much cheaper than the Creek OBH-uni (OBH-2 has been discontinued). Good luck.
