You really shouldn't use the x7 without opamps installed. Are you 100% sure they are inserted all the way?No I tried with different op-amps it's the same issue. Even I don't have any op-amps installed it's just constant noise on my speakers/headphone nothing else.
Creative Sound Blaster X7 - Detailed Review & Impressions
- Thread starter earfonia
YES I'm 100% sure I tried all the OP AMPS I have. and they work very all well on my ZXR Soundcard.
It's not the first time I'm rolling OP-AMPS
What im guessing is the Sound chip inside is fried If not then I don't know.
Without OP-AMPS I tried my ZXR and it didn't make any noise so I'm positive this unit is gone for good.
Just received a reply from the ebay seller:
"You are the worst customer ever my friend. I will ask paypal and ebay to step in to the case because the machine wasn't faulty or couldn't have been as its new and almost never used. Do not buy ever again anything for people. I cant accept something that you have for 2 week and works fine and now you saying is broken. Ehat if you break it and now you want to sent it back? Lets see what ebay will say about.
Right my only hope is Paypal money back Guarantee and to ebay seller angry response LOL.
Magic Man
- Mar 9, 2014
To be fair to the seller, you replaced IC's - you could easily be the reason it no longer functions. It's neither his nor PayPal's fault.
ctaxxxx
Everything sounds so close to my sound, I do not notice 5.1 everything sounds like it's happening in front of me. Do I have something to set up in the PS4 menu? Have put on the PS4 Toslink and Dolby. Is it correct that way?
Is the Dolby indicator light on? If it is, then I still suggest that a headphone upgrade might be needed. Software can only take you so far.
I typically stay away from gaming headsets honestly. I've heard some and they all sounded terrible to me... Get yourself a quality audiophile headphone and a separate mic for chat if you don't have one already. Preferably (semi or fully) open back headphones, assuming your price range is under $500, as this will help with separation and staging a lot. I can't help you in this price bracket, but I've heard good things about AKG.
Not really my fault as on creative websites it's clearly says that you can swap the OP-AMPS in your choice to get the best sound possible and if I do mistake on swapping then the OP-AMPS gonna burn not the Unit itself.
I'm sure there is something burned inside and ofc it can't happen by swapping the chips, maybe the Adapter which I received is not supplying enough I/V.
But I checked the PSU with my MM and it shows exactly 24V.
Right now I don't have any time to waste for this thing.
If I don't receive any positive response from the seller then I'll have to dispute with seller on paypal.
They also list compatible chips on their website. Granted, the list does not include each and every compatible model (neither Sparkos nor Burson are on it despite the fact that multiple users reported them to be compatible) but it should be a good start on what works and what doesn't.Not really my fault as on creative websites it's clearly says that you can swap the OP-AMPS in your choice to get the best sound possible and if I do mistake on swapping then the OP-AMPS gonna burn not the Unit itself.
illram
- Nov 24, 2016
When you run line out is it normal for Bass to be grayed out and locked at 25% in the SBX settings? My E5 allows full use of all settings in line out mode so I find this odd.
Mr Router
- Apr 12, 2017
Mr Router
- Apr 12, 2017
Nevermind I found out that if my headphones are unplugged the bass stays grayed out but as soon as I plug my headphones in I can select the SBX Bass hehe XDHey guy my Bass for the SBX option is grayed out for some reason and I keep shutting the device off and on and I even reset the x7 sound blaster software settings to default and it still stays grayed out. Any fix ?
sent my X7 to creative they said they will repair or replace the unit
Can anyone recommend 5 channel power amplifiers to go along with the X7's 5.1 line out. I've got a set of sattelites from a previous Gigaworks S750 system to use. Not really looking to spend over £200.
Can anyone recommend 5 channel power amplifiers to go along with the X7's 5.1 line out. I've got a set of sattelites from a previous Gigaworks S750 system to use rated at 70W per channel. Not really looking to spend over £200.
Is there any Dual to Mono [URL='https://www.google.co.uk/search?q=Dual+to+Mono+adapter+op+amps&rlz=1C1CHBF_en-GBGB760GB760&biw=927&bih=954&tbm=isch&tbo=u&source=univ&sa=X&ved=0ahUKEwig1Y7BtenYAhVEDsAKHZYKAhkQsAQIQA']op amps Adapter [/URL]for Discrete OP-AMPS like SS3601 or for bursons V6 Single OP AMPS?
mbyrnes
That's a really tough budget for 5 channels of power. Monoprice sells amps under their Monolith line. Emotiva is another that has a lot of options for a good price.
Maybe start with 2 channels and upgrade later. Both of the companies I listed have modular amps, where you can add more channels later.
Good luck, I hope you can find something. You being in Europe makes this much harder for me. Not sure of the options you may or may not have.
Better question is, why would you need one?Is there any Dual to Mono op amps Adapter for Discrete OP-AMPS like SS3601 or for bursons V6 Single OP AMPS?
https://www.ebay.com/itm/2PCS-DIP-to-DIP-Dual-to-Mono-Opamp-PCB-Adapter-OPA627BP-/221936646862
Total: 10 (members: 0, guests: 10)
