genclaymore
You could use that Razer surround software, sure its not CMSS3D headphone but atleast it will do it.
Hi,
I just bought a Creative ZxR + a PC360 (planning on Q701 soon) and I can't find the correct settings on gaming... I'm playing mainly FPS, and i need to boost the footsteps, reloading from ennemies (pinpoint accuracy).... but not sacrifying others sounds... and have a nice surround effects and soundstage. I'm new in audiophile area, and i dont know the differents terms etc.... I need some help please! Thanks !
I gathered as much after fiddling around with the settings, but it's still weird that the virtual surround is practically non-existant when using the RCA out...
So what's the best settings for in game surround? Is it Headphone in Window control panel (not ZxR control panel) and 5.1 in game? Or what?
Well your PC360 already has a great sound stage so you shouldnt have issues with accuracy. Just leave SBX surround at its default slider setting and make sure your windows speaker setting is 5.1 without full range speakers. You could try scout mode which is supposed to help with making footsteps clearer but I heard its more of a gimmick. Also make sure your in game settings have 5.1 enabled. Only other setting that should be enabled should be crystalizer which will help with footsteps although I am not a personal fan.
Leave your EQ flat or if your headphone produce more low end, then bring that down to hopefully bring some more clarity to the finer details.
It's not weird at all. RCA out uses a different surround virtualization/space calculations that are meant for speakers in front of you. Not headphones on your ears. If you want HRTF the way its meant to be then you have to plug your headphones into the Headphone out port.
When you go through the speaker setting wizard(right click on sound blaster z and hit "configure speakers") in the sound settings for windows, the last step is to decide whether your speakers are full range or not. This is shown by small speaker vs bigger ones on the little picture.
It generally affects the crossover for lfe or the 0.1 in the 5.1 setup. (The subwoofer speaker). I remember reading that a creative rep had said this is the better setting for headphones with sbx.
I think the mic built in is awesome. It seems to be pretty accurate in its pickup pattern or "cone". I don't have any background noise being picked up. To be honest its the only good part about the ACM.
Ok so if i got it right, i uncheck everything there, left/right speaker and surround speaker uncheked? that's it ?
