RPGWiZaRD
- Jan 31, 2010
I lost count how many days I've waited for my card to get shipped, probably around 3 weeks. waaaaaaahh T_T
What a nice package....directly from Japan....best seller ever!
Congrats on your ZxR my friend! hehe!
Don't forget to share your impressions
Is this a limitation from the ZXR or Asus Xonar one?
My settings:
It is because the digital output of the soundcard "only" supports a sample rate up to 96khz. Thats normal, my X-Fi works the same way.
What I want to try to do, as soon as I get my ZxR, I will connect the ZxR through toslink to my E1 and then back to the RCA-IN into the card using the RCA-OUT from the E1 and connect the headphones to the ZXR directly. Just for a test. I really want to know if there is any noticable delay and noise using this method.
Because, actually your card is doing nothing when using SPDIF through the digital out. All the processing is done by the E1. But you'll get the advantage of the cards DSP (effects,EQ and so on).
Thats also how I got my setup right now.
RIP my XFI Platinum, you have been wonderful.
but you will live in my 3Dfx voodoo P4 pc
You imported that ZxR from Japan? Didn't think people would go to such lengths here...though if I had to import a sound card from Japan and cost wasn't an issue, I'd consider it for the Onkyo SE-300PCIE.
X-Fi hardware seems like overkill for a 3dfx-based build, though. The OS I'd generally run for a 3dfx-based system is Windows 98 SE, and I'd most likely run some kind of Aureal Vortex2 card in that case. Also, Win9x drivers don't exist for the X-Fi line, to my knowledge.
If running XP, then Win9x-era games start having issues, and most titles had moved away from Glide on to Direct3D and OpenGL by that point, in no small part because 3dfx had already been bought out by NVIDIA then.
To phrase it more clearly, when using S/PDIF, the sound card's DAC is being bypassed, and the external DAC that you've connected it to does the digital-to-analog dirty work...but the source signal has still been pre-processed by any DSP effects enabled by the sound card itself.
I just got my ZXR in the mail, I can confirm what some others have said here. I'm sorry I can't give a good description in audiophile terms but, the sound quality is definitely degraded by the little module. The music was lacking any liveliness when i plugged into the ACM, but from the back of the sound card it's quite vibrant(I'm listening on HFI 780s, to various types of black, death, power and doom metal)
