paulguru
- Dec 27, 2014
Anyone can say me if the bloated bass of zxr can fix with internal EQ ?
I've got a quick question!
I'm currently running an ASUS Xonar DS. I know it's not the best card. Do you think I'd see gains if I switched to a Sound Blaster Z? My current setup has be plugging my headphones (Audio Technica A900x) into the wired remote control for my 2.1 speakers (Creative I-TRIGUE L3800), which is hooked into the soundcard. I'd love to hook my headphones directly to the soundcard, since there is sometimes some "interference" that can be heard when the sound is too quiet with the headphones.
I mainly use my headphones and listen to various music genres and play games.
Thanks!
Anyone can say me if the bloated bass of ZxR can fix with internal EQ ?
Wow. I just got it installed a little while ago and the difference between the SBZ and the Xonar DS is amazing. The sound is beautiful and clear. Thanks for your reply!![]()
Interesting since I so often read SB-Z sounds better in games but Xonars sound better for music, including the DS/DSX. Are there any more comparisons you can make between their sound differences?
Oh, your SBZ is more clear because you had your DS plugged into a wireless remote for speakers. Yeah, that might make a difference for clarity.![]()
I was going to add that even headphones that "don't need an amp" can benefit from an amp, and the SB-Z is a lot more powerful than the DS, so I thought that was going to be the reason for the sound difference.
My Auzentech prelude is about to die. I probably going to replace it with the ZxR. I now have a Bose Companion 20 hooked to my soundcard. But I'm thinking of replacing those also. What is the best way to go with this soundcard? Some active studio speakers, computer speakers (like my current Bose), or something else, like an amplifier and some speakers?
Ugh.Did you disable the motherboard's on-board audio, in the BIOS, when you installed the SB-Z?
Is the SB-Z set for 2-channel output (speaker or headphone) and any Dolby setting not enabled.
A normal external DAC only takes in a 2-channel PCM (uncompressed) digital audio signal.
One of the features of Dolby is DDL (Dolby Digital Live), which can compress up to 6-channels of digital audio, which is one of the features the SB-Z software comes with.
Compression is need to send up to 6-channel of audio thru S/PDIF (optical & coaxial), so if the SB-Z is sending a compressed digital signal, thru the optical, the external DAC will not be able to un-compress it, so the DAC can not read the digital audio signal.
So make sure any Dolby setting in the SB-Z's control panel is set to off.
I bought the damn card to utilize the card's surround sound features on my external DAC.
I'm screwed, then?
DH through optical to my DAC worked fine with my STX...I'm really puzzled here.
Ugh.
I'm screwed, then?
