Creative Sound Blaster new series Z, Zx & ZxR
Jun 22, 2015 at 9:44 PM Post #2,883 of 3,462
Is it just me or whenever I plug my headphones/iems into the ACM the sound quality is crappier than when I plug into the soundcard itself? I sometimes use EQ to boost bass but it distorts with ACM. If i plugged directly to soundcard, no distortions.
Jun 23, 2015 at 2:13 AM Post #2,884 of 3,462
It isn't you the ACM is known to mess with the sound quality, most people don't use it and just plug their headphones directly into the sound card. You could make your own if you have the skill.
Jul 5, 2015 at 5:06 PM Post #2,886 of 3,462
I thought the ACM is  just a passthrough and it doesn't do anything to the sound? so the sound should be untouched?
I like to use the ACM because its so convenient while gaming or even watching movies or listening to music. I didn't notice any change in sound quality. I tried switching back and forth and didn't notice any difference.
Jul 5, 2015 at 6:38 PM Post #2,888 of 3,462
So how do you guys hook up your headphones straight to the soundcard without the ACM? Cause the Headphone outut of the ZxR has this 1/4" plug, and the 1/4" adapter that are included with the ZxR are the twisted one, so you need a 3.5mm jack that can twist into the 1/4" adapter, then plug it in the Headphone output of the ZxR.  So how do you guys do it? Do you have to buy a different 1/4" adapter where it doesn't twist, but the push in type?
Jul 5, 2015 at 6:52 PM Post #2,889 of 3,462
You buy a 3.5mm to 1/4 adapter that plugs right onto the headphones, then you can plug the headphones into the plug on the ZXR. Monoprice has them for 41 cents.  Here http://www.monoprice.com/Product?c_id=104&cp_id=10429&cs_id=1042903&p_id=7139&seq=1&format=2 if you are in the USA.
Jul 5, 2015 at 9:32 PM Post #2,890 of 3,462
Thx man.  I am going to MicroCenter on Tuesday to pick up the X7 and the 1'4 adapter too.
Jul 6, 2015 at 9:58 PM Post #2,891 of 3,462
ZxR just dropped to $169 on Amazon.  Lowest price to date.  Was thinking about one of these but I think my new ASRock motherboard gives me the performance I want.
http://www.amazon.com/Creative-Blaster-Audiophile-Performance-Headphone/dp/B00AQ5PK6I/ref=sr_1_1?s=pc&ie=UTF8&qid=1436234187&sr=1-1&keywords=zxr
Jul 7, 2015 at 3:19 AM Post #2,892 of 3,462
With ZXR can i drive good enought a Sennheiser HD6xx ?
Someone say me my HD600 is not good with my sound card but ... im using it with HD600 and i cant keep the High gain mode because the volume is extremelly high ( windows mixer at 10% in normal gain :( )
Jul 7, 2015 at 2:28 PM Post #2,893 of 3,462
Regarding the ZxR... does it make any sense to connect it to a receiver ?
I have a Marantz NR1605 connected to Bose Speakers and just not getting the 5.1 sound I would like, currently I have it connected to HDMI on my GTX980
Jul 7, 2015 at 6:05 PM Post #2,894 of 3,462
Any comparisons of the Sound Blaster Z or ZX (not ZXR) amp to things like the e10k?  I've seen a couple people say it powers DT880 or DT990 250 fine, but I've read more people say it can't. So I'm trying to figure out how it compares to a more known amp such as an e10k or similar.
I have a Xonar DG, and I think it'd be more powerful than that, but the question is how much more powerful.
