i know this is a bit off-topic, but a lot of you here know your stuff.
my question is, does the windows speaker configuration for 5.1 or stereo have any effect on sound that goes through optical out for to my Dac/Amp?
What about when i use my SBZ DSP for virtual surround, but decide to turn off virtual surround when i want stereo for music. under this setting, windows is configured for sbz/speakers as default, and "play stereo mix through digital out" is select in SBZ control panel.
I tested it, and it seems to have no effect when i turn off DSP and want purely stereo, but i wanted to be sure.
I guess I'd say that whether you process the signal or not, it's stereo either way? Unless you checked the box for Dolby Digital Live output encoding. I could spend a month re-writing a user guide or changing the UI, if it was my job
Stillhart has a cool method where his music player is set to output ASIO and bypass the SBX suite, so he can "leave" on the processing settings but music is played straight. I use iTunes (been using it for a long time, when the four options were ripping CDs manually, downloading illegally, or a subscription service where you have to keep paying to "rent" music, or iTunes) and a Sound Blaster X7, so I either switch on stereo-direct, or select my "music" preset.
