kiwikozo
- Sep 10, 2014
It sounds like you loved the Sound blaster Z but didn't like the mic quality, did you disable the mic options in the panel or did you disable the mic boost which some times messes with the quality of your voice. I found with the omni that i had to disable The mic boost and other options before my voice came out clear, even when I had the omni on my desk away from my mouth, they was still able to hear me, but that was because I had the option on that allow you to talk softly and still be heard. Also some of the voice changer options also can also cause issues too. Did you try another PCI-E socket? I have a friend which uses the Z as well and uses a mic and he doesn't have your issues as he turns off all of the voice effects and mic boost.
As I found the DG/DGX to have muddy bass which was also boomy. I would suggest you try the suggestions I mention before shipping the Z back again. Going external might solve your issues as I have had similar issues but reguards to noises in the audio which was gone when i switch to the omni. The major thing is the U7 has Dolby home theater V4 which is very poor software if your looking to use virtual headphone dsp. If you have no plans of ever using it, then that wont really matter. But a Used omni that you linked is $49ish dollar's, The only thing with the omni is that it only supports 48khz and 96khz playback, meaning you might have to use a re-sample plugin if you use foobar 2k, tho you might not have to if you use the default Direct sound option in foobar.
Edit: the sound blaster omni is the replacement for the X-FI HD Usb which was on the market. the Omni just has a better headphone amp over the X-Fi HD/pro Usb.
Thank you, so, so much. You saved me a fair bit of hassle! What do you think about the X-Fi though?
And I won't be using surround, just using stereo headphones. The thing I'm worrying about is that the U7 comes with a basic control panel, and I think that my microphone might be really fuzzy? Or does this make no difference?
Will the U7 provide me with better sound for listening to music, videos etc with my M50s? I listen to FLAC music.
I did try to change some of the settings and I found that the acoustic eco cancellation causes some fuzzy-ness and the microphone boost is what is causing the static after I say each word.
However if I don't use Microphone boost it's so, so quiet and I can't be heard. The quality is fantastic but I can't be heard.
I also tried another Pcie slot and that changed nothing.
One strange thing is when I test my microphone in the Sound Blaster panel it is perfect, even when I use microphone boost. But when I record myself using the windows sound recorder or when I use programs like skype, teamspeak... it just turns crappy.
I find it weird how I HAVE to have the noise cancellation on else all I hear is noise. And my headset comes with a noise cancelling mic.
Another thing I would like to add, I really don't care for any gaming features like scout mode and the likes. If I play fps games I'd rather just hear the regular sound. Same with any other game, no strange vitalization!
