x7007
- Jun 30, 2012
Hm, one thing I learned with headphone connection, does the volume change every time you unplug it and plug it ?
Beacuse sometimes I have lower volume while settings and everything stays the same and only the physical contact. Maybe I didn't have it with the Xonar Phoebus because I didn't really unplug it much.
Would it be better to use the 6.35mm Jack Plug Audio instead the 3.5mm, maybe this will make sure there won't be an issue ?
http://www.amazon.co.uk/Adaptor-Premium-Quality-Headphone-Adapter/dp/B002JP6JEK/ref=pd_bxgy_MI_img_z
I have the one that I got with the DT990 600 ohm, would there be any differences ?
