Hello
I've just bought ZxR(few days ago) and i'm using sennheissers PC360 for now. I don't know how much different they are from HD360 Swordchan, but i've tried them with hub and without - coudn't tell the difference, maybe on better cans there is more apparent effect...
I've upgraded from onboard soundcard and can definitively say that sound quality have improved it's livelier, more rich it's really nice.
I was slightly dissapointed with the two mics in the hub i read opinions that they work as intended and pick up sounds from the space before them... well... friends on voice comm heard dinner getting ready from kitchen two rooms away from mine so it didn't work quite good
I've played with the settings but to no avail. Also they complained about my voice getting slightly cut out and sounding different(and just plain bad) every time i spoke
. The only feature that worked (and really goood too) was noise cancellation. PC360 is a headset and the mic on it is VASTLY VASTLY better, i woudn't change it but the better cans i ordered don't have mic in a set so i was hoping for the solution provided by creative.
And thus I have two questions:
- Can anyone recommend good clip-on mic or desk one (for communication from room with other sound sources than my voice
- The headphones I ordered are 300Ohm HD800 and I know the first setting in soft is for 32 - 300 Ohm and the second is for up to 600Ohm cans, so I should use first one, but it's just on the egde of threshold, my question is - Is safe to check 600 Ohm settings with them just to see if it's worse/better or would I risk frying them or sth?(my soul would shatter) Yeah i'm noob at this
Please if anyone could help with my concerns...
