Creative Sound Blaster new series Z, Zx & ZxR
Feb 4, 2014 at 10:26 PM Post #1,831 of 3,462
@Germanium.. post up a guide please with photos. Your mods sound extraordinary, and I'm sure we'd all love to see how you achieved it. Many thanks.
Feb 4, 2014 at 10:31 PM Post #1,832 of 3,462
  @Geranium.. post up a guide please with photos. Your mods sound extraordinary, and I'm sure we'd all love to see how you achieved it. Many thanks.
this next week end I'll try to do this
Feb 4, 2014 at 11:01 PM Post #1,833 of 3,462
Not much you can do with that as it is very small& some of my mods take a fair amount of room, a full expansion slot above the ZXR card is used for the metalized film capacitors as they are definitely not small by any stretch of the imagination. I suspect you usb soundcard is bus powered & has only one power supply rail for the analog out & as such can not even be direct coupled as you need 2 power supply rails going to the opamps in order to direct couple. Otherwise you would have at least 1volt if not 2.5 volts at the output. This voltage would cause problems for any amp that does not have an input capacitor.
I've seen some mods done to the Indeed and Bravo amps that add similar components. I would not mind using my Recon3D USB "unshelled" if it sounded capable... honestly I think this one performs lower than my first one.
Pretty sure some USB ports can use 2.5 volts... like an iPad charger, and my Gigabyte motherboard is advertised as having more juice on hand.
It may not be possible... but I'm confident it could at least be made better.
Feb 5, 2014 at 3:47 AM Post #1,834 of 3,462
The 2.5 volts D.C. I'm talking of would likely damage any direct coupled amp not to mention any headphone connected to the output. I do not have your unit to be able to look over the circuit & right now can't afford to go buy one just to do that.
Feb 5, 2014 at 3:53 AM Post #1,835 of 3,462
Select stereo speakers from Creative CP, then select 5.1 speakers from Windows CP and tick SBX. If you want to use SBX speaker HRTF that is. If SBX stays on in OpenAL games like Mirror's Edge, it means that you are using Generic Software (which 99% sure is the case unless you have manually edited the config file).
No, everything's perfect with setting up the Creative card's ID under device, ALAUDIO etc...just not in Borderlands 2.
Feb 5, 2014 at 3:25 PM Post #1,836 of 3,462
You might be right :frowning2:
Still, as I said it's kind of a redundant/spare device right now, I wouldn't mind mailing it to you if you were curious about enhancing a device that can do virtual surround for PCs AND consoles...
Feb 6, 2014 at 8:38 AM Post #1,838 of 3,462
There is no optimal solution that works for everyone. You have to do it yourself. Basically if you use the headphone out, I'd start with disabling every SBX Pro Studio feature and then enable Surround and adjust the slider until you are happy with the surround sound (though 67% is usually quite good compromise and also default setting). Crystalizer and other things are really personal, you have to test those out yourself. Crystalizer is essentially v-shaped equaliser.
You have made this change under
[WinDrv.WindowsClient]
AudioDeviceClass=ALAudio.ALAudioDevice
For those that do not know, you need to change this too:
[ALAudio.ALAudioDevice]
MaxChannels=128
CommonAudioPoolSize=0
MinCompressedDurationGame=5
MinCompressedDurationEditor=4
LowPassFilterResonance=0.9
UseEffectsProcessing=True
DeviceName=Sennheiser HD 595 (Sound Blaster Z)
If you don't have the ALCapsViewer it's still easy to figure out the correct device name.
However, this only applies to Z series cards. Non-Host base X-Fi cards have rather meaningless device name.
Feb 6, 2014 at 10:39 AM Post #1,841 of 3,462
I'm also interested in seeing germanium's guide.
Feb 6, 2014 at 9:43 PM Post #1,842 of 3,462
1Sale - Sound Blaster Z, $54.99 shipped
Why didn't anyone mention this earlier? It's going to expire in a little over three hours, or to be more precise, 12:00am EST.
I have to resist the urge...still quite a bit of money to spend just to review something and probably resell it later...
Feb 6, 2014 at 11:13 PM Post #1,844 of 3,462
  How many of you guys use the surround effect in the sound blaster control panel? I have tried it out a few times and I just found that makes the audio sound weird to me.
SBX Pro is sort of the whole reason for buying it.  It won't sound good for stereo, only 5.1 sources like games where it provides virtual surround via HRTF processing.
Feb 7, 2014 at 1:34 AM Post #1,845 of 3,462
To clarify... no, I don't use the surround feature while listening to music (because I don't like extra processing on stereo audio), but I DO use surround while gaming.
