shawn_low
- Aug 6, 2009
Hi,
I purchased a creative EM-U from someone on HF.
Got a couple of issues with it.
USB input works with Headphone output. YAY!
I plugged in both Optical sources and SPDIF sources but there is NO SOUND from the headphone output. Should this be the case? Do I need to turn anything on or press buttons to switch to SPDIF? I removed the USB input and pressed all conceivable buttons to no effect.
Also, there are several diodes/LEDs which DON'T light up.
1) Power On
2) SPDIF (both Coax and Optical when there is a connection). Pressing the buttons doesn't do anything.
3) 48V on.
So, I lift the thing and there's a rattling inside. I look closer at the diodes/LEDs and it seems like some of them are a different colour (there's a reddish/orangey glow under all of them except for a few). This includes the ones listed above.
When I power on the machine, these lights come on:
Midi: Out
Direct Monito: Main, SPDIF, OFF, MONO on.
Mic/Hi-Z/Line: SL
NO other lights come one.
I suspect the diodes broke off, hence the lack of lights to indicate things. But will this affect SPDIF input?
Thanks.
1) Power On
3) 48V on.
Midi: Out
Mic/Hi-Z/Line: SL
Thanks.
