Thanks for the replies to this thread. Something like the Jabra is what I was looking for.
Hey D2000, any updates? Could you post them if/when you do? I've been looking for a solution very much like what you're proposing to do.
[size=12.727272033691406px]
Hey buddy yeah I finished them a while ago just haven't gotten round to updating anything.[/size][size=12.727272033691406px][/size]
Here's some pics. I ditched the the HTC A100 - it was a terrible reciever with tiny range and no controls, i should have seen it coming. I quickly returned the useless piece and I ordered the Samsung HS3000.[/size]
WOW is that way better. Heaps of controls, INCREDIBLE range (i did a test on my property with an iphone 4 and got to 185 metres, though i did have to keep the receiver in perfect line of site after 30 metres.) The sound quality is also excellent with APT-X BT profile. voice prompts and things of the sort too![/size]
Okay on to the pics![/size]
While it looks like they are even more bulky now, the additions are actually hardly noticable. The HS3000 and E6 are only weigh 30 grams together so its barely a wieght difference. Even so, i added a low profile 30gram weight on the inside of the other cup to ensure a true balance.
From front on you can really barely see that the HS3000 is there as it lines up with the side of the headband but from the side on it's kinda obvious when the E6 sticks out.
I was going to have them inside the cups, and was very close to doing so, but i had to keep in mind that i wanted easy access to the controls and charging ports, and so the sacrifice of aesthetics was justified.
For those after a more permanent mod i would just ditch the shells of both the HS3000/E6 for even lower profile and weight. Then solder extensions or extend the existing controls to the surface of the cup and embed them inside. You could also remove the obtruding L8 cables by hardwiring the circuit together on the boards. I plan on using the two pieces for other things once the HD215's conk out, and wanted the reversable option
Nothing to fancy to mount the E6/HS3000 - just a little superglue for a quick bond and then some epoxy resin after. The superglue is a cyanoacrylate, which partially melts the surface of each plastic during the chemical reaction and strengthens the bond, but for a more durable bond the epoxy is a good choice. Superglue shatters under high impact. Epoxy takes the hit for the rig
APT-X is higher quality BT and the E6 has been thoroughly explored already but needless to say the SQ is pretty top notch. Great isolation (as they're dj cans.) The highs, lows and mids are also pretty darn resolving (for a portable BT) set. I suppose its all the use of the cans in the past that helps - nothing like 2000 hours of burn-in to loosen the driver
All in all, there's heaps of options. My favourite is the way the E6 is positioned for easy access to the volume rocker using my thumb. The media, power and calling controls on the HS3000 are all exposed, but the volume rocker isn't. I thought that the E6 rocker was ample, and since the HS3000 has a volume memory simply set it on high and control with the E6.
Charging is slightly more clunky, with two different usb cables and ports (mini and micro) but I plan on joining the circuitry or connecting them to a unified battery low profile battery (my eye's are set on an old 1500mA one from a broken Mophie charging case.)
At the moment i get about 8 hours of charge out of the HS3000, and i just charge both up when one needs charging, though the E6 is rated at more than 10 hours.
On the whole I'm rather pleased. I'll post some more updates tomorrow perhaps before work.
EDIT: Don't bother with the jabra - the HS3000 is way better and just as small.
