junkimchi
- Jun 16, 2008
That's going to be some killer sessions of Ouendan you're about to play
Alright, thank you.
Now, i hooked up my e17 + Dt 880 ( 600 ohm) with my PSP and they got pretty loud.
I am curious if it would be better to use the e17 since it is an DAC and may be better than the PSP/DS DAC?
What do you guys think?
If it gets loud enough, there should not be reason to hook it up to the e9k and buy an additional cable or?
Thanks for the info wes008.
I have 2 Questions:
I am connecting my PSP to my Sony hx 755 Tv via component cables. Then i capture the Audio with an optical cable whch i plug in from the Tv to the e17/e9k. Am i still double amping?
If i connect my DS to my e9k instead, would it be a better solution?
You are not double amping! Actually, you are going digital out of the TV, which mean you are using the DAC in the e17.
Of course it is better to hook up the DS to your e9k, since it should be a better amp for your dt880. I don't know if it is worth it, though.
no just for gaming.
So the component cable can? is it coax? ( PSP)
