Sylmar
- Mar 11, 2016
I moved from Spinfits to KZ Starlines. My most preferred tips for the moment and they costs next to nothing.
Thanks for the reply. I do have a set of KZ starlines, they are quite easy to insert into the ear but the are hard and uncomfortable. I guess somehow maybe only spinfit works for me as conventional eartips seal would not last when I wear my motorcycle helmet (move a lot, like turn your head, vibration).I moved from Spinfits to KZ Starlines. My most preferred tips for the moment and they costs next to nothing.
I think there is a big difference in how people experience comfort where eartips are concerned. The Starlines are pretty comfortable for me but a friend of mine cannot stand any type of eartips, they all hurt him.Thanks for the reply. I do have a set of KZ starlines, they are quite easy to insert into the ear but the are hard and uncomfortable. I guess somehow maybe only spinfit works for me as conventional eartips seal would not last when I wear my motorcycle helmet (move a lot, like turn your head, vibration).
Just FYI for people looking for alternatives to Comply tips, Rebound tips work very well. They have a variety of diameters, including up to 5.5 mm (equivalent of comply 600). I feel that they do not attenuate the highs as much as Comply (the foam portion in front of the tip tube is shorter than Comply).
Rebounds? Link?
I'm curious about the spinfits, but every silicon based tip I've ever used just slips out eventually.
Anybody selling their excess spiral dots? My guess is M or ML, would love to get a variety pack in an envelope
I appreciate the reply but neither me nor my spouse would do well with smalls I think.I might have some extras in Small if you would be interested.
JVC Spiral Dot sizesDo you happen know how big the S and MS are?
L:14mm (.550)
ML:13mm (.511)
M:12mm (.472)
MS:11mm (.433)
S:10mm (.394)
EDIT:
Best place to buy the JVC Spiral Dot in size MS?
