danny93
- Sep 20, 2010
Im curious what soundcard do you own...please enlighten me!
Also how is the Asus the better card any first hand experience, or you just going on numbers like that review?
When did i say the Titanium HD is the best? I said its probably not quite as good going on reviews for music (slightly) but for gaming its a card built from the ground up for this segment and the STX slightly dips its toes into the water in this regard.
The Ti HD is the most reccomended card for gaming...period
You clearly just looked at that website and as the STX had higher numbers the reviewer said it was the best so you now troll around threads like you have heard it saying its the superior to the Ti HD when in fact you dont have a clue...its been clear time and time again:
First you said hook up the Mixamp to a soundcard...seriously What
Then you said only go for Ti HD for EAX...again What (developers dropped this years ago)
You went on to say how replacing opamps is bad...
Then you link to a review who doesnt even talk about the sound quality and bases everything off numbers...
Im sure you can see where Im going with this...you are clueless, and the only reason im continuing to reply is because its rather amussing and im curious as to what ridiculous statement your going to make next...please keep them coming
Yeah you can swap them, but if something goes wrong im sure they wont just give you a new card for free.. Also if you really want to start messing around with op-amps the same can be done on the asus essence card, so it still remains the better card
Anyways, topic starter should just read stuff the experts say that tested all major cards instead of 1 guy who owns 1 card and claims it to be the best
whatever topic started decides im sure the HD wont disappoint even though the asus ones are better cards if you dont care about EAX.. Good luck!
