I have a Metric Halo ULN-8 ($5995) Pro audio interface, a Prism Orpheus ($4999) Pro Audio Interface, a Prism Lyra ($2500) pro audio interface, and several other pro audio interfaces. 2 years ago several engineers and I all tested the DACs in them and with null testing, all of them nulled. Now if 2 audio files null that means they are exactly the same.
Imagine my disappointment when my friend's Schiit Modi nulled with my multi thousand dollar interfaces. So after screaming that null testing was bulls***t, we did a listening test and all failed to distinguish between the expensive DACs and the cheap ones.
Cut to today and I come across this thread and realized that I had an Aune T1 mk2 TUBE DAC. So I fired up Logic Pro X and decided to do a null test.
Now Aune claims that the tube in the T1 "flavors" the signal with whatever tube you're using. This was suddenly extremely exciting because getting an authentic tube sound in the digital realm is sort of a holy grail for me.
So I run off an 8 bar piano riff through a Schiit Fulla, a Prism Lyra, and the Aune T1, mk2:
The $79 Schiit Fulla and the $2500 Prism Lyra nulled
It was pretty much expected but damn, how disappointing.
However, the AUNE T1 MK2 DIDN'T NULL. OMG. Not even CLOSE to nulling, full glorious piano with no breaking up.
Next, I decided to swap out the Phillips E188CC-7308 tube and put in the stock Electro Harminix:
THEY DIDN'T NULL EITHER!!!! It was a bit close though because it was the same amp, just a different tube, so audio was breaking up, coming in and out.
Why am I so excited?
Because now I can put an AUTHENTIC tube vibe on every single song I produce and mix now. If I want to "warm up" a *cold* digital sounding song, I can just render it with the T1. Other things i can use it for. I can send guitars though it, omg, the possibilities are endless.
So, I can now say, all DACS are NOT the same, well, tube DACs are different if they work the same way as the T1.
