TehNomad
- Aug 5, 2008
Code:
(Parts ripped off Joshatdot's list with a few changes)
+the ALPS pots from Tangent's site
+the RS boards
I plan on driving my SR-60s with this CMoy, and I'm probably going to stuff it in an altoids tin (which is really appealing to me).
1. Should I choose different gains?
2. Do I need an R5?
3. Is this the best opamp?
Code:
[left]P12388-ND CAP 470UF 25V ELECT FM RADIAL CMoy Kit - C1 470 uF EF1105-ND 1.0UF/100VDC METAL POLY CAP CMoy Kit - C2 1.0 uF 4.75KXBK-ND RES 4.75K OHM 1/4W 1% METAL FILM CMoy Kit - R1 100KXBK-ND RES 100K OHM 1/4W 1% METAL FILM CMoy Kit - R2 1.00KXBK-ND RES 1.00K OHM 1/4W 1% METAL FILM CMOY KIT - R3 1K OHM (GAIN 11) 2.00KXBK-ND RES 2.00K OHM 1/4W 1% METAL FILM CMOY KIT - R3 2K OHM (GAIN 6) 10.0KXBK-ND RES 10.0K OHM 1/4W 1% METAL FILM CMOY KIT - R4 ED90032-ND IC SOCKET 8 PIN .300 GOLD CMoy Kit - 8-DIP Socket OPA2227PA-ND IC DUAL PRECISION OPAMP 8-DIP CMoy Kit - Op-Amp 232K-ND STRAP BATT ECON 9V I STYLE 4"LD CMoy Kit - 9v Batt Straps CP-43502PM-ND CONN JACK AUDIO 3.5MM 4COND CMoy Kit - IN/OUT Jacks 160-1708 LED 3MM HI-EFF RED DIFFUSED CMoy Kit - LED Red 226-3104-ND KNOB CLR/MATTE .50"DIA 6MM SHAFT CMoy Kit - Knob[/left]
+the RS boards
2. Do I need an R5?
