Sir Nobax
- Feb 1, 2007
Hey guys,
In the upcoming vacation (next week for me
) i want to do a little project.
And because i now dislike the sound of my Creative Zen Vision stock (got spoiled at a meet with a Tomahawk) i thought what the heck, let the Cmoy building begin!
I've heard quite a lot about the Cmoy, and i guess its a nice start.
While searching info on it i made myself a nice layout, with the components i want to use.
This is the stuff i am going to buy (unless you guys say not to).
Code:
Some opamps: (to play around with them)
OPA2132PA
TLE2082CPE4
TLE2142CP
OP275GPZ
The amp is going to run from either 4 NiMh's, or a single 9V rechargable.
I probably will be printing the PCB myself (the laserjet trick) later on.
But i've run into troubles, i cannot indentify a single channel Pot from an dual channel Pot!
I've seen two, but they both look kinda strange, one has 7 pins, the other looks like it got only 5. While the layout i made teaches me that i need 6 pins.
http://nl.farnell.com/jsp/search/pro...sp?sku=1191749
http://nl.farnell.com/jsp/search/pro...jsp?sku=918635
(yea i know its dutch, but the important things are in english anyway)
Can i use any of these ? [EDIT: i figured out that the 5 pin should work just nicely]
Then i still have a question: is the layout (and the selection of components) okay?
[edit] a little mistake i made on the drawing, the on/off switch has 10k Ohm on it, that should be on the Pot ofcourse)
Code:
Code:
[left]WELWYN RC55C-10K0DIRESISTOR, 0.25W 0.5% 10K Ohm MULTICOMP MF25 4K7RESISTOR, 0.25W 1% 4.7K Ohm (also used for controlling gain) WELWYN RC55C-100KDIRESISTOR, 0.25W 0.5% 100K WIMA 10602824118820TCAPACITOR, 2824 0.47UF 63V (block) (on Pic 40V!) NICHICON UHD1C471MPD6CAPACITOR, 470UF 16V[/left]
OPA2132PA
TLE2082CPE4
TLE2142CP
OP275GPZ
