Clip+ Sound Quality, really??
Apr 26, 2010 at 4:37 PM Post #152 of 179
Apr 27, 2010 at 12:34 AM Post #153 of 179
Originally Posted by JaZZ /img/forum/go_quote.gif
Can anyone answer these two questions?
1) Does the Clip+ support 32 GB expansion memory? I've read contradictory statements.
2) Can you apply the shuffle function to both on-board and external memory at the same time – to have full 24 (or better 40) GB covered by the shuffle mode?
I'm sure that there are a few users who could answer this question from personal experience.
Apr 27, 2010 at 12:57 AM Post #154 of 179
Yes, you can shuffle across int/ext memory.
Music->"Play All" pulls all available music from internal and card memory.
Apr 27, 2010 at 2:36 AM Post #155 of 179
Hey, thanks!
Apr 27, 2010 at 5:49 PM Post #156 of 179
A little off topic, but which micro SD card do you all use with this? There are some SanDisk 16GB cards for $35, but reviews have said it has a high fail rate, and one customer said it might even be fake, so I'm trying to find a good 16GB card at a reasonable price...thanks!
Apr 27, 2010 at 6:41 PM Post #157 of 179
I'm waiting for this one. (Don't have the player yet.)
Apr 28, 2010 at 12:40 AM Post #158 of 179
59.99 shipped may not qualify as reasonable to you, but if you don't want to wait, this Class 6 card is a solid choice: Newegg.com - A-DATA 16GB Micro SDHC Class 6 Flash Card with SD adaptor Model MicroSDHC CL6 16G SD ADT
I was a little leery about trying an A-data card at first (some of their cards get reviewed as having poor quality) yet I've had it for almost a year now and it's been great. Worth noting: it takes about 35-40 minutes to fill up the 14.9gb usable space using an external reader...I would hate to go class 2 with a card of this size and wait around while it fills up.
Apr 28, 2010 at 1:08 AM Post #159 of 179
Ah thanks, yeah $60 is reasonable as long as it works well. Kind of sucks to double the cost of the Clip+, so might have to go with 8GB and cut some stuff...but we shall see..thanks for the recommendation, much appreciated
Apr 28, 2010 at 1:10 AM Post #160 of 179
I got my sandisk 8gb card from ebay for (IIRC) $20AU.
Possibly a fake, but it works just fine, and for the money, I can afford to have it die. I think they (too old a transaction to find out the seller) were selling 32gb for 40-50.
It's a music player, so I can't think of any reason why there'd be a need for fast cards... as long as it stores data and works, you should be fine (fakes included).
Apr 28, 2010 at 2:39 AM Post #161 of 179
NP. Great to have the extra space if you can afford it, seeing so much music there using folder-browsing with rockbox has definitely been worth it to me.
35 minutes or so using Class 6 is already a relatively long time when it comes to wanting to fill my 16gb card with all new music. Real-world may be longer or shorter, but going by Class speed, I'd hate to wait 1 hour and 40 minutes+ using a card rated @ Class 2.
Apr 28, 2010 at 3:15 AM Post #163 of 179
Ah, that'd be my problem, I don't have enough music to fill my current 10 gigs...
Apr 28, 2010 at 8:52 AM Post #164 of 179
What would people say it was like with 320 kbps MP3 (converted on slow/high quality from FLAC)?
I'm waiting on a Neutrik plug for my TripleFi and I don't have any other IEMs (I don't want to test with full-sized headphones).
Apr 28, 2010 at 8:54 AM Post #165 of 179
Not too different to iPod speeds.
It's quicker if you use fewer, larger files from my experience (as you'd expect).
Class 6 is worth maybe $5 - $10 on top, as it's not necessarily hugely quicker than Class 2.
