Clicks and distortion when converting from 96/24 to 44/16
Dec 14, 2013 at 8:55 AM Thread Starter Post #1 of 2
daniel0407
Dear all,
I am trying to downsample some tracks to make a kind of comparation between sample rates, to verify to myself if I am able to hear any difference. To be sure I am using the same mix of the song, I tried to downsample the tracks using "Switch Sound File Converter", which works fine when changing formats (for example, flac to m4c), but creates clicks and distortion when downsampling. I try with different formats and codecs, and all the time the same.
Any advice on how to properly downsample the file?
Other question: is there any way to carry a blind test using JRiver?
Best Regards,
Daniel
Dec 14, 2013 at 9:04 AM Post #2 of 2
Best is if the original file is type of WAV.
If you don't use foobar2000 for the ABX (there are SRC and ABX plugins available) Voxengo has a free utility for the conversion - r8brain.
http://www.foobar2000.org/
http://www.voxengo.com/product/r8brain/
