Hi, it seems to me that this is the biggest CCA thread on Head-Fi so maybe someone can help me out even if my question is not on sound quality:
My smartphone (Huawei P9 lite) doesn't support OTG and its DAC is not worth its name. At home, or anywhere with a wireless network, I can easily connect to my CCA and have good quality music. But on the go, with no network around, that connection is not possible - or is it? Might there be a way to set up a closed network using my phone as router for it to connect to the CCA? Has anybody tried that?
Thanks for any thoughts!
Have you tried to enable your smartphone as wifi hotspot with your same home wifi SSID and password? This should cheat CCA to think it's at home and can transmit.
I use this trick for my wifi-only devices on the GO to use my cellular data plan on a transparent way for those devices. Not yet tested with CCA but it should work.
