Mojo ideas
Member of the Trade: Chord Electronics
- Oct 20, 2015
Okay so your able to take the battery out it could be anything up to three years old.I have never taken mojo out of my house or place it in a hot area, so if it was exposed to high heat for a long time it could only be the heat that mojo generates. Battery was swollen and operational so those internal contacts in the battery did not detached. Yes I was careful removing the battery, I even got some latex gloves as I noticed the battery was oily, no visible spills, just felt oily. I'm no stranger handling electronics/computers/lenses, I even grounded my self so no static discharge would happen to the electronics, so unplugging the battery connector was very simple and yes I'm not thinking about putting it back. But if you read my second post you'll find out that the problem is really not the removal of the battery, it has more to do with the damage the battery did to the pcb board due to the excessive down pressure applied to the circuit board. I cant be 100% sure but like I said I have some experience with electronics and I have seen this problem several times in motherboards, so I can tell the mojo pcb board has been microfractured as the battery was pressing really hard on it, you can tell this because using a latex glove I can apply similar pressure with my fingers to the board and then the mojo works as it should, no more loud pops or static backgroung noise, as soon as I take my finger off the problem reappears. Unless such pressure is required by design I can't think of any other reason I'm having this issue. Please advise! and thank you for replying.
Can you remove it and dispose of it safely in a battery recycling bin. Then return the mojo without its battery to your dealer or to your regional Chord distributor or if you can’t do that you may PM me with your Detailed address and send the mojo without battery directly to me at Chord Electronics in The U.K. where are you based?
