Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
post-12264026
Post #9,511 of 40,385
x RELIC x
The West Coast, Canada
What player you used with mojo? I wonder how much it improves the sound of the tons of 192k mp3 in my iphone...
I'm not sure if you can hear it but I find 192kbps MP3 to be audibly terrible. The Mojo won't magically transform trash to treasure so to speak. It's exceedingly revealing and as they say 'garbage in, garbage out'. Same with poor masters... especially with poor masters. That said, well recorded music with decent file compression (my minimum threshold is 256kbps AAC) will simply shine with the Mojo.
Reactions: spook76
post-12264120
Post #9,512 of 40,385
xeroian
have Hugo and mojo will be arriving shortly. does it come with USB and coaxial cable ? I will be using it mainly with Beyer dt880 600 ohm and redmi s1/fiio x3 2nd gen as transport .
Only a very short USB cable with Mojo. Hugo comes with many variants of USB and optical cables though so you should be fine.
post-12264184
Post #9,513 of 40,385
xeroian
Thank you all. I guess I will try later on Sunday as it's 4.33am here in the UK.
I think the Mojo is cute too; (adorable). It's size as with the Hugo is desktop perfect. I genuinely didn't expect to see four members post in a row that their Mojo charges silently.
I also think I would struggle to wait ten hours for it to charge first time. I wondered if that was for battery conditioning. Whereas used straight from the box charging and playing, it's still going to see a full length charge.
I totally completely and absolutely understand why folk love the Mojo, from what I read in pro-reviews, and impressions. I feel re-enthusiastic, and grateful to each of you.
Please make sure you check Amazons T&Cs before deciding to open it. Amazon UK usually say 14 days in either used or unused condition because of Distance Selling regulations (although the regs. have a different name now as they are EU wide) and a further 14 days (28 all together) if unopened. Over Christmas they extend this but it may just be the unopened allowance they extend. If in doubt about their rules then return the Mojo, buy it again and start using it immediately. Why wait until the last day before checking out whether something is suitable or faulty? Do it on day one.
post-12264857
Post #9,514 of 40,385
episiarch
London and California, mainly
What do you pair your mojo at ?
In terms of headphones, there's a variety depending on mood and use case, but it drives all of them well (again, to my ears, better than anything else I own).  The current favorite is ACS Evolve, but others I use or have used it with, with good results, are HD580, K501, K550, SA5000, D2000, ER-4S and JH13 (pre-freqphase).
In transports, it's been Macs (both optical and USB, sometimes with Audirvana Plus and sometimes without), iPhone (CCK + the included USB).
In material, almost nothing better than 16/44.1, and a lot of it is AAC 320 or AAC 256.  Even those compressed tracks sound amazing through the Mojo.  I'd much rather listen to AAC 256 on Mojo than something higher-res on my Lavry DA10.
For me it's just making everything better.
post-12264975
Post #9,515 of 40,385
trtrtr607
just wonder if anyone experienced crackling sound through Chord stock ASIO output in foobar? I am currently running Windows 10 and installed driver from Chord, and these crack and pop sounds appear while playing back MP3/AAC files, but not DSD files. When I switch to WASAPI, all just work right. I previously used Windows 7 and have no problem with ASIO at all.
post-12265049
Post #9,516 of 40,385
zeddun
Has anyone tried the Mojo with either versions of Dita the Answer and if so is it a good pairing?
post-12265233
Post #9,517 of 40,385
Mojo ideas
John Franks
Sponsor: Chord Electronics
We at Chord have had a lot of experience with all the Dita products we like them all and I personally carry some always.
post-12265245
Post #9,518 of 40,385
sonickarma
Website
earphonia.com
Dita Truth has good synergies with MoJo
post-12265376
Post #9,519 of 40,385
salla45
I'm using mine also with the X3 ii. It's a headache to get the 2 linked up. I got a bespoke cable made by a HEADFI member derGabe for not much money at all and it works like a charm! I used Sugru to modify it a little as below, and now the X3ii and Mojo are just continuously "bolted" together with velcro and i even put some bumper feet on it so it can stand up nicely. If i were you, i'd contact derGabe and see if he can knock one up for you. It took a bit of time, so to avoid frustration get in early. I don't know many other places, other than Moon Audio who will do one, but thats 100$ or something + timescale.
I also have the T1 beyers and they work beautifully with it. Your 880's should be great too!!
Hope you enjoy as much as me.
post-12265406
Post #9,520 of 40,385
TokenGesture
Previously known as avl06
Somerset
Somerset
Disappointed with mojo (in)ability to connect to the Pioneer DAP over USB.  I've tried numbers of OTG cables, most don't connect at all, and the two that do display a lot of interference.  Not really fit for purpose.
post-12265437
Post #9,521 of 40,385
cattlethief
My mojo can connect to my pioneer no problems and if you are getting interference you will have to switch your wifi off.
post-12265499
Post #9,522 of 40,385
TokenGesture
Somerset
Somerset
I guess you are right. I wanted to stream, but I guess I can just do that with the Pioneer sans mojo.
post-12265501
Post #9,523 of 40,385
masterpfa
I have found any connection issues to be with the device you are tying to connect to the Mojo and/or cables. I personally don't have the Pioneer DAP but I did have a great deal of problems with my OnePlus One. Long story short, got an OTG from One Plus and all worked, I have since found other cable that will also work.
Any noise interference can also be caused by a bad connection in the USB chain (either at the DAP or DAC end) or interference from the WiFi.
It's a shame that you haven't found a USB OTG that's Fit For Purpose took me ages to get items that worked.
post-12265591
Post #9,524 of 40,385
Mython
...and the Chord publicity pics prove it!
post-12265665
Post #9,525 of 40,385
zeddun
Thanks everyone for your comments. I'm looking for a good universal IEM to use with my Mojo and my Calyx M. Based on comments I'm going to purchase rhe Answer from a fellow head-fi member. I previously had the ie800 and really liked the sound but the ie800 wouldn't stay in my ears unless I was stationary and didn't really provide any isolation. I also tried the K3003i but didn't like the fact that it distorted with my Calyx M due to its low impedance so that I had to use an extra M Jack. Looking forward to trying the Answer.
Users Who Are Viewing This Thread (Users: 0, Guests: 8)
