will an ipod nano 6th gen work with the mojo?
No not natively as it doesn't have a digital output compatible with the Mojo.
Thank you. I think you are right that I could try the Mojo and return it. I am just confused on that point because the Mojo is factory sealed. Amazon might have to sell it as box opened then. However I think our UK distance selling regulations mean I should be able to open and try it. I think Amazon allow for us trying stuff. I have only two weeks left to try it and make a hassle free return then.
It might make more sense if I explain again why I bought a Mojo. Then why it never got opened. I bought it because I saw the review in What Hi-Fi October-ish; their Awards Issue. It seemed too good to miss and I picked one up from Amazon, with no further online searching. 'I intended to use it primarily as a desktop DAC' as I read that many people do with the Hugo.
During the time from when I ordered it to before it arriving I started browsing online about for the Mojo. Already being a Head-Fi member I found this thread. Then I saw the reports that users were having and how they were working around it. 'Some people reported stuff that meant it might not be practical for desktop use'. It meant that my decision to open the Mojo when it arrived was put on hold. I figured wait and see what fixes or ideas transpired. Then the issue showed up on this thread that the first second of music got missed. With no criticism of Chord, it took weeks before it was explained why. (I think it was prompted by me asking.) Once I understood why, and people assured me it was OK, that issue was resolved for me.
As of now the only issues that I could have using it as a desktop DAC are:
1. making a noise when charging,
2. cutting out when charging and playing.
The second point I think I could cure with fixing cooling to it. Therefor I think I will go ahead and try it. I had just two days ago contacted Amazon about these two concerns, explaining the Mojo is still factory sealed. I was assured if a problem arises, I will be able to return it. I was left still nervous though because I am not someone who buys online to audition. I was buying the Mojo blindly to keep, based on review.
Think of the Mojo (and Hugo) as a full sized CD player that has a variable line level output (for pre-amping) - there is no amplifier inside the CD player...@xtr4
i understand the FPGA designs makes the dac and amp essentally the same... what im really trying to get at is, can the FPGA's amp functions be bypassed so it is used simply as a DAC, and the two 3.5mm outs are true line outputs to prevent double amping
Paste
I don't want to remove Hugo every time for portable use therefore planning to get mojo shortly for portable use.
Hi.
Has somebody pared the DX100 to Mojo?
Which is the best way to connect it, via optical or coaxial?
Could somebody recommend me one cable that can be buy it in Amazon?
Thanks
Pha 3 has balanced connection, mojo does not, would that be a factor for you ? Idk....
