Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Nov 11, 2015 at 5:43 PM Post #4,802 of 42,765
I had the same problem with the DX90 until I turned the volume on the player down to zero.  It won't affect the signal going to the Mojo and seems to help considerably with the pops.
Thanks, I tried this but it doesn't stop the problem. Im using the coax cable that came with the DX50 with an rca female to 3.5mm mono adapter, sounds great apart from this popping sound.
Nov 11, 2015 at 5:44 PM Post #4,803 of 42,765
Works as well for me. See my pictures I posted a few days ago. One of the pictures shows a dsd playing on the chord. I tried it on my media pc as well and it does play. The white can look pink or blueish at certain angle. As in dirty white
Thanks! Mine is sounding great with my new HE 560's!
Nov 11, 2015 at 5:55 PM Post #4,804 of 42,765
  I bought AK100 MK2 for my Chord Mojo. In the back, it says AK100 without MKII. But at the System Information it does say MKII with 2.42 firmware. Do I have AK100 or AK100 MK2 ??
Thanks...
My AK100 Mark Two reads Mark II on the back
Nov 11, 2015 at 6:28 PM Post #4,807 of 42,765
Thanks...
I bought the AK100 mk2 from Todd (TTVJ) and it has 2.30 firmware (What is different between 2.30 and 2.42?). In the back of the unit said AKMKII Made in Korea by IRIVER.
Nov 11, 2015 at 7:12 PM Post #4,809 of 42,765
  That's means my AK100 is not MK2 version then...
Sorry, I don't know what the diff between 2.42 and 2.30, but mine came with 2.42.
Was your box thin or thick? The original unit had a smaller box - the DAP was in a drawer that slid out - the MKII was a thicker box where the the top came off - the box also should state whether it is a MKII or not. Did you get a box? Hopefully you paid by CC or Paypal
Nov 11, 2015 at 7:25 PM Post #4,810 of 42,765
I have an AK100 original with firmware 2.42. Works well except every once in a while it seems to lose its memory and needs to reread the library files. Since I have 190 gb/~5500 files on it the indexing then takes 5-10 minutes. Anyone else's AK's have "senior moments" like this? Thanks
Nov 11, 2015 at 7:28 PM Post #4,811 of 42,765
Yup... It is a AK100 :) confirmed by the box like you said...
Oh well, I thinks that's fine since it will forever married with the Mojo...
Nov 11, 2015 at 7:30 PM Post #4,813 of 42,765
Mine have not do that... try to turn off the auto scan...
Nov 11, 2015 at 7:31 PM Post #4,814 of 42,765
Well all the elements finally arrived, and after a couple of days listening to AK120>Mojo>64 Audio U12s I'm staggered by how good this set-up is. Shiver-inducing. It's actually distracting me from concentrating on work at times. I usually stay away from 'end game' proclamations, but I can't imagine getting more pleasure from a rig than this.
Nov 11, 2015 at 7:34 PM Post #4,815 of 42,765
While I'm waiting for my Mojo I dug out the Headroom Total Bithead. Did the same thing back in the day. USB and analog input, cross feed and two headphone jacks. I guess that Tyll guy was on to something.....
