BattousaiX26
What is actually happening when it "overheats" ?
It will automatically turn off when it overheats
@NaiveSound, just checked ifi iematch. that penon audio impedance adapter is lot simpler and does not have wire. it simply has resistance in the path of both the channels. there is no reason the addition of a simple resistance should effect the sound quality.
here is the link. http://penonaudio.com/3.5mm-Male-to-3.5mm-Female-Impedance-Adapter
But which one does one get?
don't expect these to be any better than the ifi iematch.
Uh... it absolutely will. It's like adding output impedance to your amp. If you have a multi-way BA with a curvy impedance curve adding a resistance in series will absolutely change the response, and quite drastically so.
Yes, surely it will affect the damping factor, and consequently the reproduction of transients.
i have 75, 150 and 200 ohms adapter..what do you want to know ?here is the link. http://penonaudio.com/3.5mm-Male-to-3.5mm-Female-Impedance-Adapter
I recently got this one, and surprisingly, it works perfectly with my iPhone 7 Plus:
http://amzn.to/2ilm2Q1
It's a nice slim form factor too.
