- Apr 18, 2016
Sennheiser ie80 is perfect for you
Yes the IE 80 has lots of bass and you can tune it to your preference. The synergy with Mojo is quite good actually. It makes the IE 80 sound warm and non fatiguing
Okay. This isn't going anywhere. Almost every amp will have a ruler flat response and slight roll off at the edges. Which is why I'll say again, you should use parametric EQ. Parametric being the operative word here. Graphic equalizers will have the problem you're talking about... Parametric means you can shape it yourself.
Your headphones will have the biggest impact on the frequency response ofyour system.
Thanks, I'll give it a listen for a few days. I just hate being super critical about music / frequency responses and switching between devices constantly. It's headache-inducing for me! Would you say the Mojo has a better sounstage for movies? As stated before I'll only use stereo headphones, in this case Fidelio X2's.
Considering I'm only using it in one place never on the go... would you say there are better alternatives for the price of the mojo?
Thanks, great to hear! Looking forward to the Mojo arriving tomorrow! Really hoping I can immediately tell the difference.
No.
Like this.
i have equalify pro for my spotify, it looks kinda the same?
Did u install Asio or Wasapi to your foobar?
Okay so use a 100Hz low shelf to bump the bass to something you like. The taper will prevent it from gaining the mids.
Wasapi doesn't show in Foobar2000 settings at all. WHY?
In JRiver, both ASIO and Wasapi show up.
All the information regarding the lack of a separate amp stage is in THE THIRD POST OF THIS THREAD as the thread title suggests. Rob Watts, the designer of Chord DACs, has graciously shared his design approach and I suggest anyone with questions refer to the third post for answers as @Mython has spent a considerable amount of time gathering and organizing this information for users.
TL;DR
The Mojo indeed just uses the I/V conversion only in the output path. Think of it as the Mojo is driving headphones from the Mojo's discrete line output. It has to do with the substrate noise lacking from the DAC (and the resulting incredible measured performance) that he is able to do this without analogue filtering, or extra op-amps in the path. No other non-Chord DAC takes this approach because they require extra filtering in the analogue stage. Again, Rob explains it better in the third post.
Rob has expressed, in the third post, that upsampling is a bad idea. In particular he is not a fan of DSD.
Here, I'll quote it for you:
Upsampling to DSD will do nothing but hinder the sound quality. Mojo sounds better over PCM as it is.
U need to install it by yourself.
Eg: Google "Foobar2000 wasapi"
Download
Go to Foobar2000 preference
Install (find the place of downloaded wasapi)
Finish
Still in preference; Output - Choose mojo event
Ok I will try this in the morning :/
