shultzee
Personally I never run battery powered devices plugged in all the time. I've had too many lithium batteries lose capacity by doing this. Also, it's known that leaving a lithium battery near full charge for extended periods of time is very stressful for them. Chord has said it's fine to leave Mojo plugged in all the time, and I'm not about to debate that statement. I just would not do it myself. If I do use it in the desktop system I just run it off battery, unplugged, until it needs a charge.
I'd suggest contacting your retailer for warranty service regardless.
I agree with your take totally. I have had a lot experience with lithium batteries and you are correct they will lose capacity. We also had a rule of thumb from the mfgs. of high end lithium batteries that when not using them for awhile they should be stored at 60% capacity. That is not relevant to the mojo situation and the batteries I am referring to cost more than the mojo themselves . If chord says you can leave it on charge all the time so be it but I am personally going to cycle mine occasionally.
