Ugh 3 weeks and still no email response to clarification I needed. I guess that was that.
Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
- Feb 11, 2008
Anything I/we can help you with, or was it an ETA?
Unfortunately not I'm afraid, thanks! "Luckily" back to school so a cable upgrade is not 1st priority.
Bricki
- Aug 16, 2016
If I had to guess what could be causing the differences between both optical outputs is that one is a CD player that's optimized to play music and the other is a computer that is not. One thing I do know is my Oppo makes a great transport. I wouldn't think that the differences we hear has anything to do with the Mojo other than it being so clear that it's hard not to hear them.
Yeah I am definitely not suggesting that there's something wrong with mojo
I understand that the output from my CD player is gonna have better timed data than my computer (ie. worse jitter)....but other than that what differences could there be?
I probably need to ask Rob directly
Set845
- Jul 12, 2016
Yeah I am definitely not suggesting that there's something wrong with mojo . IMO the only dac that would be a significant upgrade would be DAVE.
Yeah I use my Oppo as a transport to the Mojo. The Mojo is just so much better. I never would have thought that my portable DAC would be better than my home rig. Crazy. So now I happily use the Mojo as both. Thank you, John and Rob!
Curious about what's your home rig?
Same thing happened to me brother
Set845
- Jul 12, 2016
Oppo BDP-105D, Dared 845 tube amp, Paradigm Studio Monitor 20 speakers and sub, and a Mac Mini. For portable iPhone 6, Mojo, and Etymotic ER4S iem. I also have an old Xin Supermini III headphone amp that I don't use anymore.
Edit: I also have a Dragonfly Red that's not in the same league as the Mojo but I use it for walks.
TheTrace
- May 30, 2013
Thank you much for the information.To answer your question, the iPhone does output bit-perfect audio when you're using iTunes and Tidal. No fussing required. The Onkyo app gives you the ability to play high-res files.
Rob Watts
Member of the Trade: Chord Electronics
- Apr 1, 2014
Regarding upsampling of audio files - If I were to compare to video.To me watching a film that is originally shot in 720P and have my Oppo-105D upscale the content to 1080P, or add their scaling feature brings me better results. Don't quite understand how upsampling from windows to 384khz using Chord ASIO bypasses the Mojo dac capabilities any different then if I were to use 44.1? From my experience, using a higher sampling rate the only compromise is imaging not being as precise, but at the same time
everything else sound becomes more relaxed and more analogue sounding - especially for someone like me that listen to a lot of tracks that do with vocals and don't care for precise imaging placement, is a clear winner.
Mojo actually upsamples and filters everything to 2048 FS (eventually getting to 104 MHz) and it does this in two stages. Firstly upsamples to 16 FS via the WTA filter, then there is a second filter that then takes you to 2048 FS.
Its the upsampling to 16FS where the clever stuff happens - that's where the 44 dsp cores are used - and this process is orders of magnitude more advanced than what a PC can do. So what we are talking here is not the need to upsample, but how well that upsampling is done. So if you want the best sound quality, let Mojo have the original file and let it do the upsampling.
To take your video example when you are upscaling to 1080p from 720p. Would you prefer to have it done crudely and very simply, or done with the best video processing possible?
Rob
Deleted
Rob Watts
- Apr 1, 2014
Oh boy,
I was getting out of my car today after a nice long listen with my Mojo and it fell out of my hands and onto the ground. I can hear something rattling around. It powers on, but I'm afraid to test it. Obviously if something is rattling, something is wrong. I emailed Moon Audio and Chord, anyone else have any ideas? So upset this happened
I think you are worrying too much - I have dropped my Mojo lots of times, and its fine. The rattling is on new units too, its just the optical flap rattling...
Modern surface mount tech is very reliable to extreme acceleration or G - it was originally invented to go into missiles to survive 100's of G.
Rob
Deleted
rkt31
- Oct 14, 2014
every time I start an evening walk with mojo, the first note itself prompts me to wonder , is there any dac on earth which can better mojo ? when I listen to hugo, hugo seems to be better than mojo in some areas. so ultimately it comes to Dave which definitely is better than both. it means no other brands can beat the chord dacs for the same price. I am so happy with mojo. I would suggest people to buy mojo both for portable and home use. in speaker set up there may be few issues due to small size of mojo but those can also be overcome with simple tricks. there are some high quality 3.5mm stereo to RCA adapter by audioquest and other brands.
Rob Watts
- Apr 1, 2014
Yeah I am definitely not suggesting that there's something wrong with mojo. IMO the only dac that would be a significant upgrade would be DAVE.
There are two problems that USB has against toslink - and one benefit. The benefit is that timing comes from Mojo - but with toslink the incoming data has to be re-timed via the digital phase lock loop (DPLL) and this is not quite as good - but you will only hear the difference via a careful AB test, so it's in practice insignificant.
The downside with USB is the common ground connection. This will mean RF noise will get into Mojo, making noise floor modulation worse. Now I go to very careful lengths to remove this problem by using lots of RF filtering, and double ground planes on the PCB, but even minute amounts of RF is significant. The other problem is down to the way that digital code works - which is in twos complement. So zero is in 24 bits binary is 0000_0000_0000_0000_0000_0000. If the signal goes slightly positive then we get just one bit changing to: 0000_0000_0000_0000_0000_0001. But if it goes 1 bit negative all the bits change to: 1111_1111_1111_1111_1111_1111. Now the problem with this is that when a bit changes, more power is needed, and this injects current into the ground of the PC - and the ground will get noisier. Unfortunately the noise is worst for small signals. Now the problem with this is that it then couples through to Mojo's ground plane, and the distorted signal currents will add or subtract to small signals - thus changing the small signal linearity. This in turn degrades the ability of the brain to re-create depth information, and so we hear it in terms of depth being flattened. What is really weird about depth perception is that there seems to be no limit to how accurate it needs to be, so the smallest error is significant.
So with toslink we do not get these problems as there is no common ground - so no RF noise, no distorted signals on the ground, and it will sound smoother with better depth against a noisy PC. But the problem can be almost eliminated by using a power efficient USB source that is battery powered - such as a mobile phone. But with noisy PC's the only way of solving it is to use galvanic isolation on the USB - but this draws power from the source, and we can't do that with mobile devices. All of Chord's desktop DAC's have galvanic isolation on the USB, and then you can't hear whether its a noisy PC or a mobile phone. In this case, USB sounds slightly better than optical, because we have the (tiny) timing benefits of USB.
I hope that explains - its a complex subject.
Rob
Total: 17 (members: 0, guests: 17)
