miketlse
- May 8, 2016
Does anyone know why line level mode is set to 3V output? This is quite high. Today i have been using my Mojo to feed my Pure Jongo T2 speaker through the aux input, and when I set the Mojo to line level mode the Jongo sounds distorted even at low volumes and I need to reduce the level on the Mojo.
It is all explained in post #3.
Selecting line out is just a short cut to 3V. You can then adjust the 3V using the volume buttons as normal - i think 3v and then 4 presses of the -ve ball, will get you to 1.9V (but check post #3 to be safe).
