psikey
- Jul 15, 2008
Is the Mojo supposed to be taken outside?
I really can't see how one can fit it in their pockets - I mean it's undoubtedly an amazing device but I don't see how you can really use it outside. Having to use my HA-2 because of the form factor.
Doesn't fit in jeans pocket easily but fine in a jacket/trouser pocket. The Z5mini used purely as a portable music source for the Mojo, I use a S7 as my actual phone.
Also for anyone interested, I've finally managed to get my Mojo/Z5 combination working without EMF interference (noise while over 3G/4G/Wifi).
As I posted earlier in the thread, I put a ferrite core around the cable which nearly eliminated all noise via Wifi/3G but still some with 4G but then made another change.
As I work for a company that makes transformers, I got a small thin piece of soft lamination Iron (used in transformer cores) and placed in the cover of my phone between the Mojo/Z5 and now total silence. No interference noise of any kind with a 10 minute test. Going to give it a good checkout during my lunch-break walk to check fully resolved.
Pics
Thin & Light Case with soft iron insert
Cut pieces of soft iron
Ferrite ring around cable
Highly portable coupled with strong double-sided tape and case/phone acts
as a Mojo button guard
