Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Jan 30, 2022 at 2:06 PM Post #1,306 of 10,641
I wouldn't mind the 8 hour battery life if charging was fast but it's crazy how slow the charging is with the OG mojo.
Exactly. The key metric is the charge time.
Jan 30, 2022 at 2:56 PM Post #1,308 of 10,641
If Mojo disengages battery in desktop mode then I see lot of ppl running it as desktop DAC with good LPS
Jan 30, 2022 at 3:11 PM Post #1,309 of 10,641
I did that for a while with Hugo 2, then I decided it was better just to get a true desktop DAC.
Jan 30, 2022 at 3:18 PM Post #1,310 of 10,641
"New FPGA-based charging system greatly improves battery management
This technology significantly improves charging speed, reduces power loss by 75%, and enables more efficient charging."
I guess it is not quite fast-charging.
Power loss is always a synonym for heat production. :wink:
Hopefully one can charge while listening without creating a heat gun.
Jan 30, 2022 at 3:23 PM Post #1,311 of 10,641
I wonder if my Uptone UltraCap 5v LPS will do the job ? It's been collecting dust in a drawer for a while !!
Jan 30, 2022 at 3:34 PM Post #1,312 of 10,641
I have the same LPS v1.2 that I use with my streamer. It should work fine with Mojo
Jan 30, 2022 at 3:35 PM Post #1,313 of 10,641
Charging time approx 4 hours ...​
Characteristics​
Useful info about the EQ function - actually more of a tone control:
When activated, Chord Mojo 2's EQ allows you to adjust four frequency ranges (20Hz, 125Hz, 3kHz, 20kHz) in plus or minus nine 1dB steps (18 in total) via the knobs +/- used for volume adjustment. Channel balance can also be adjusted by enabling the feature in the Mojo 2 menu.
Wish it would have had a 4K band, as that would have suited my preferences for the 2021 LCD-X.
I imagine that the Hugo 3 will have more flexible eq capabilities.
Jan 30, 2022 at 3:45 PM Post #1,314 of 10,641
It may have Wide Q so you can mitigate 4K a bit. But I’m just assuming
Jan 30, 2022 at 3:59 PM Post #1,316 of 10,641
That's a good point. It would be possible to simulate with a parametric eq to get an approximation of what the mojo2 would do. As you say, the Q value would be wide.
We will know during official release or once impression starts coming in from experienced members
Jan 30, 2022 at 5:21 PM Post #1,318 of 10,641
Too bad Chord didn't go all the way an implement full parametric EQ. I would have definitely bought it just for that.
Maybe they will put that into Mojo 3 in 2029, but I'll bet the Mojo 3 still has USB-micro for charging.
Jan 30, 2022 at 5:41 PM Post #1,319 of 10,641
I am with you on that!! Full parametric EQ would have been a killer feature, especially since I‘d be pretty sure that an implementation in a CHORD device would not create any negative effects on the digital data. But a 4 band EQ has little value for me :worried:
But parametric EQ might really be a feature reserved for the future higher end products, which makes sense from marketing perspective.
Jan 30, 2022 at 6:00 PM Post #1,320 of 10,641
Yea, but man it would be a killer feature and to me not that hard to implement. They could justify the higher versions with other things:wink:
