Guy Fawkes
yes i did itHi all, I can't recall if I have ever seen a measurement of the Mojo2 DSP in action. Has anyone even measured the actual impact on the FR?
Another question: what is your preferred setting with HQplayer with the Mojo2?
I did some EQ measurements connecting the Mojo 2 to my A/D converter to see exactly how each band behaves, I did the measurements setting each band to +9, if any of you need other settings, please ask me.
The 4 filters are positioned exactly at:
Red: Peak 20 Hz - Q 0.71
Yellow: Low Shelf 150 Hz - Q 0.71
Green: High Shelf 2,400 Hz - Q 0.71
Light Blue: Peak 20,000 Hz - Q 0.71
If you need to bring these settings into Crinacle to equalize your IEMs/Headphones you will need to set the 20,000Hz filter with a Q-factor of 0.25 (not 0,71) to get the same match as the Crinacle EQ has lower...
