Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
Feb 11, 2023 at 1:31 PM Post #6,856 of 12,455
I don’t think so no.
Not possible. The mojo outputs an analogue signal, not the digital signal that you need for wireless/bluetooth.
Thanks for confirming, I knew so, just thought to ask just in case something could be done.
You can use your phone as a transport with the Mojo 2 with a OTG cable.
I Velcro the Mojo 2 too the back of a cheap phone case and use it this way around the house.
Then detached feed from optical from a streamer.
I use Bluetooth from iPhone for the most portability.
Bluetooth lossless is coming this year .
There are 2 phones that currently support lossless Bluetooth .
I hope Poly 2 is lossless Bluetooth capable when it arrives.
Thanks but this requires me to carry the Mojo 2 around with me. Not only I have never-ever carried the Mojo 2 outside of my house but also I very rarely carry it around inside my house. For me, the Mojo 2 is a desktop solution, which can be transportable. Not portable.
Which two smartphones are currently supporting lossless Bluetooth?
Mojo is for wired headphones
Yeah, one of the best desktop solutions.
Feb 11, 2023 at 1:56 PM Post #6,857 of 12,455
The Nura True wireless iems support Aptx lossless.
One phone is the Asus 9.
Aptx lossless will roll out on more devices this year.
I’m sure Apple will have a lossless AAC coming.
I think Nura do a lossless transmitter as well.
Check out there website.
Feb 11, 2023 at 2:01 PM Post #6,858 of 12,455
Is there a way to use BTR5/7 as a source with Mojo2? I’ve tried both and no results. Maybe some options need to be enabled?
Feb 11, 2023 at 2:36 PM Post #6,860 of 12,455
Shanling M0pro+Mojo 2 is a great portable combination. M0 has a BT receiver mode to effectively give Mojo 2 BT connectivity.
Can you change songs when streaming to M0?
and what is PW Audio device attached to your Mojo2?
Feb 11, 2023 at 2:43 PM Post #6,861 of 12,455
Hello, I have a question, too, I have no prior experience with DAPs or Ultra Portable DAPs, like this one. So, when you say that this M0 pro has a BT receiver mode, what does this mean? What can be achieved with that?
Feb 11, 2023 at 2:50 PM Post #6,862 of 12,455
Yes.
The M0 has a BT receiver mode. You just connect to it like any BT headphone and steam to it. It does have basic controls on the screen to control your source.
The PW is a 3.5 to 4.4 pentacon adapter. I have mostly 4.4 terminated headphones and iems.
Feb 11, 2023 at 2:54 PM Post #6,863 of 12,455
When the BT receiver mode is activated, you can connect your phone to it like any other BT headphone.
It adds BT functionality to any usb dac.
Feb 11, 2023 at 3:04 PM Post #6,864 of 12,455
Bluetooth DACs like the BTR7, UP5 don't support digital output via USB. You'll need a DAP for that, someone above already suggested a good and inexpensive option, the M0 Pro.
It’s just I already have both BRT5 and BTR7 and I was hopping that there is a digital out. $130 for M0 Pro is not too much. It seems the best option right now.
Feb 11, 2023 at 3:47 PM Post #6,868 of 12,455
You could also check out the small Hiby daps as well?
I thought about the Hiby S3 Sabre, but it was $200+ and is out of stock. The screen is still pretty small to really navigate a larger library. I like the coax out aspect. It's almost the same height and width of the Mojo 2 though.
Feb 11, 2023 at 3:51 PM Post #6,869 of 12,455
If the M0 Pro is the same as the M1 and M0, then they used Hiby software, and one could install the HibyLink app on phones and tablets, and use the app to control the DAP. This approach has the advantage that one has a much larger display screen, which makes it easier to see/read/control the DAP.
Feb 11, 2023 at 7:09 PM Post #6,870 of 12,455
No such thing as lossless Bluetooth. When you’re talking CD quality and higher. Sample rates lower than that can be at times, but you need the best connection because devices will automatically change sample rates depending on quality of connection. Technically you can send Spotify over Bluetooth without losing anything, I think. So if it’s that type of thing you’re after, I think all phones would do that, right?
Do I have s add lol if this right, brains trust?
